Cleaning out the Shop
Cleaning out the Shop Empty Cleaning out the Shop
Post  TRUKPULR September 18th 2013, 10:25 am
Went in the shop the other day and decide to get rid of all this stuff I been hanging on to for more the 15 years.. Most of this stuff is used lightly and some is brand new still in the wrapper but just been sitting on my shelve too long.
Used Comp Cams 927-16 New Price $429.97 Will sell for Half price O.B.O.
Competition Cams Valve Springs, Part No: 927-16 opened box Valve Springs, Dual, 1.539 in. Outside Diameter, 498 lbs./in. Rate, 1.175 in. Coil Bind Height, Set of 16.
New Locks 611-16 $21.97 O.B.O.
Up for sale is a new package of Competition Cams Comp Cams Super Valve Locks part number 611-16. COMP Cams Super valve locks are wider-angled 10 degree locks. They distribute the ever-increasing valve spring loads over the retainer better than typical 7 degree locks by reducing the chance of "pull-through" failure. These valve locks are precision-machined for accuracy and are available for many popular valve sizes with or without a lash cap recess. The Super valve locks will fit any COMP Cams 10 degree retainer and are recommended for all race applications due to their superior strength.
New Two Boxes of Erson E 915160New Price $299.90 O.B.O.
Part# E915160 - Drag Race, Roller Springs - 1.640 OD dual, max lift .850, 250# @2.000
Super Clean Hi-Tensile Chrome-Silicon Steel
Specially Formed Structural Process for maximum performance & duability
Independently tested to out-perform any other steel valve spring on the market
Each set is 100% quality inspected & pressure matched
Longer life means more laps per dollar
Lower Cost, Winning Performance!
Designed for use in the demanding drag race market using roller tappet camshafts or where the increased spring pressure is required for maximum performance. Set of 16
1.640 OD dual
.860 ID
.850 max lift
250 lbs @ 2.000 installed height
803 lbs @ 1.150 open pressure
Spring rate 650 lbs
Coil Bind 1.070
Use Titanium Retainer# 516, VTR747
Use cup# 2605
Use ID Locator# 2681
Used PSI CT1242 Valve Springs New Price $399.00 Will sell for Half price O.B.O.
PSI CT1242D Premium double roller valve springs 1.580" .780" lift NEW set of 16
Damper style valve spring set of 16 Drag Circle Track
PSI, the first racing-only valve spring manufacturer in the U.S., has continually grown to offer multiple series of springs to suit the racer and performance enthusiast alike. This spring is just one of PSIs 1200-series offerings. The 1200 series is designed using advanced heat-treat processes to strengthen the base material even higher over PSIs 1000 series offerings. This process is done to increase fatigue life and offer better resistance to load loss, making a spring that is close to being application-specific and would benefit from these features. This spring was built to meet the rigors of circle track and endurance applications, with the goals of starting and finishing an event with the best spring possible to not only avoid breakage, but also avoiding load loss, which compromises your engines performance.
Spring Specs
O.D.: 1.580"
Outer I.D.: 1.155"
Inner I.D.: .755"
Seat Pressure: 250#
Seat Height: 2.050"
Open Pressure: 650#
Open Height: 1.270"
Rate: 513#
Max Lift: .780"
Coil Bind: 1.200"
Quantity: 16
ARP Ford 351 Cleveland, 351-400M Head Stud Kit; Hex ; ARP 154-4004 New Price $154.99 Will sell for Half price O.B.O.
New Ford 260 289 302 5.0 Melling High Pressure Oil Pump HP $56.96 Will sell for Half price O.B.O.
MEL-M68A
HIGH PRESSURE Melling oil pump for the following Ford engines:
1962-65 260ci
1963-68 289ci
1968-2001 302ci (5.0L)
The M-68HV provides increase in oil pressure over stock oil pumps.
OEM quality, economical price. Don't waste time installing an old worn-out oil pump when you can get one of these brand new Melling oil pumps at such a low cost. These pumps are manufactured from high quality steel with all new components and are individually hand turned and pressure tested to guarantee they'll perform superior to O.E. Every Melling oil pump is completely pressure-tested, including idle and bypass pressure, before it leaves the factory.
Brand:MEL Manufacturers Part Number:M68A
Push Rods 351m/ 400
9.500- .080 5/16 Set of 16 $27.88 Will sell for Half price O.B.O.
Competition product
9.600 .080 3/8 set of 16 Hardened Ends $75.00 Will sell for Half price O.B.O.
New Trick Flow 429/460
8.350 .080 5/16 set of 16 $50.00 Will sell for Half price O.B.O.
8.250 .080 5/16 set of 16 $50.00 Will sell for Half price O.B.O.
New BBC Laser cut header Flanges $ 48.00 Will sell for Half price O.B.O.
New Carb Spacers
Still in packaging Jegs 1 Phenolic Carb Spacer $42.00 Will sell for Half price O.B.O.
Out of packaging but never used Jegs 2 Phenolic Carb Spacer $56.00 Will sell for Half price O.B.O.
Used K&N Air filters
3 X 14 New Price 43.99 Will sell for Half price O.B.O.
4 x 14 New Price 53.99 Will sell for Half price O.B.O.
6 x 14 New Price 65.99 Will sell for Half price O.B.O.
6x 14 Pre filter new price 27.99 Will sell for Half price O.B.O.
I have Three Dominator Carbs
1050 Works great will take $1000.00 for it
1150 Needs a carb kit well take $850.00 for it
1250 This one was on ShaZam for the last 5 years $1200.00
I have one 4150 1000 Cfm Holley Double Pumper will let it go for $850.00
And One 4150 Holley built for Ford 980 Single feed dual pumper Mechanical secondarys. Came off a 1968 428 SCJ. Very Rare and hard to come by, it has Tags. Need $1250.00 for it.
I have a Trick Flow Tunnel Ram with 2 - 1150 Domi Carbs Linkages and Air cleaners for the TFS A-heads. I paid $2250.00 Will let go for $2000.00
OK now for the High Dollar Stuff Sitting on the shelve.
Two sets Manley 221448-16 Valve Springs Used Still have 320# Seat Pressure 1010# Open $225.00 each
Two Sets Crower .904 Roller Lifters $425.00 each
Two Sets of Push Rods
Manley 3/8 .080 9.150 and 9.550 $85.00
And CV Products 3/8 .080 9.150 and 9.550 $85.00
Have a set of T&D 1.9 Shaft rockers with stands $850.00
Have a set of Jessel 1.73 Shaft Rocker with stands $1025.00
Ill add to this list as I find more stuff out there
Go ahead and shoot me on offer on anything here ... Just don't insult me.
Dan ..
Last edited by TRUKPULR on November 16th 2013, 6:14 pm; edited 1 time in total (Reason for editing : Removed Cranks and lowered Prices on some stuff.)
TRUKPULR
TRUKPULR
http://www.shazampulling.com
Cleaning out the Shop Empty Re: Cleaning out the Shop
Post  dtimmer September 18th 2013, 11:49 am
What heads to the rocker stand fit?
dtimmer
http://www.visnerengine.com/
Post  TRUKPULR September 18th 2013, 4:40 pm
Trick Flows A-460 heads
TRUKPULR
TRUKPULR
Post  TRUKPULR November 16th 2013, 6:15 pm
Bump New Prices
TRUKPULR
TRUKPULR
Post  onefastpickup January 4th 2014, 10:04 pm
have you sold that tunnel ram intake and carbs? you can reach me at 402 310 2072
onefastpickup
Post  bbf-falcon January 5th 2014, 1:09 pm
If the header flanges are for 2.25 tubes I will take them.
Post  TRUKPULR January 5th 2014, 2:46 pm
No header flanges have a 2" Square type hole. there's lots of meat on the flange to open them up to 2.5".
Dan
TRUKPULR
TRUKPULR
Post  TRUKPULR January 5th 2014, 2:47 pm
onefastpickup wrote:have you sold that tunnel ram intake and  carbs? you can reach me at 402 310 2072
I Still have the intake and carb's and linkages.
Dan
TRUKPULR
TRUKPULR
Post  windsor January 5th 2014, 6:15 pm
You have a pm. Thanks.
