Pro-filer Heads ?
+14
Kevin93
steve1071
Old blue Racin Team
D. Sea
capri-sun
brad
017stosh
56Tbird
David Willingham
18 posters
Page 2 of 2 Previous  1, 2
Pro-filer Heads ? - Page 2 Empty profiler heads
Post  steve1071 August 6th 2009, 11:09 am
do these heads use the same valve train as the c-head?
steve1071
Pro-filer Heads ? - Page 2 Empty Re: Pro-filer Heads ?
Post  dfree383 August 6th 2009, 11:21 am
Not sure I've never needed heads that big, seen few sets, but I'm sure Randy or Charlie could answer the question.
Post  bruno August 7th 2009, 2:50 pm
017stosh wrote:bruno
been a little tight lately. we are not going to dyno at this time but we are going to put it in the car and go racing. i will post video's when we run it. if you want to see the car it's going in go to you tube and type stosh's mustang. those videos are with the A heads single dom.
stosh
any new updates ????
http://WWW.CKRME.COM
Post  Kevin93 August 7th 2009, 2:55 pm
Hi guys. Hope you find this information useful. We have used the Thors on both a 598 & 638 engine with nitrous. We strictly race 1/8 mile. My experience is I think they performed better on our 638. That being said they worked good on our 598 engine also. The gentleman I sold my old Thors to has a top sportsman tube chassis Mustang & has been I believe 6.80's in the 1/4 at over 200mph with 2 foggers on a 598 engine. They are working pretty well for him. I just believe the more cubic inches you can put under the Thors the more they will like it. You guys take care & have a nice day!!!!
Kevin93
Post  Nevs August 7th 2009, 3:48 pm
Tony Bischoff ran the Thors on a 646" engine with a lot of nitrous, in Pro 5.0. He went mid 6.50's@213+ at 2600# as I recall. They seem to like the nitrous, if you know how to tune it. He's run even faster in NMCA trim, I believe in the 6.30's.
Post  jason August 19th 2009, 1:00 am
Not sure but im thinking of going with the trick flow a-460 head with the 1.35 intake valve if anyone has a comment on those heads good or bad it would be great .
jason
jason
Post  dfree383 August 19th 2009, 6:46 am
The trick flow a460's work great.
Post  rmcomprandy August 19th 2009, 12:09 pm
The Profiler heads WILL use a "C" cast style intake manifold easily. A 5/16" or so intake gasket spacer is needed; the bolt pattern does crossover.
I believe that Charlie Evans has those spacers IN STOCK.
Art Francis says his "Thor Heads" are a cross between the Ford "C" and "E" heads but, taller and use a completely different intake manifold and valve train.
Post  mikep August 19th 2009, 11:15 pm
bruno wrote:but Lou is running them on a 518 cu in and he is using well over 1000hp of the juice on the motor and i believe he is turning it up to 8000 rpm .....
Lou has the profilers!
mikep
Post  RGL August 22nd 2009, 12:35 pm
[quote="rmcomprandy"]The Profiler heads WILL use a "C" cast style intake manifold easily. A 5/16" or so intake gasket spacer is needed; the bolt pattern does crossover.
I just did this deal with the c manifold on profiler , I used a 3/16 thick gasket i got from cometic , and the floors line up pretty good, match the roof line, and its all good. You'll need to slot the bolt holes a good bit, but they will work good. The only "issue" you will find is that the water outlets dont line up from the head to the manifold. Since i already had the heads bolted on and the rockers on it, i just filled in about 1/2" of the water outlet on the manifold , then ground the floor down some to make it all line up . I normally precheck everything, but i was guilty of not catching this during the mockups , if i had i would have welded up the water outlet on the head, then put a bung on the outside and brought the water out of the end of the head , I could then just glue the intake gaskets on and leave there for a good while during teardowns ( they are about $ 40 pr)
RGL
RGL
