C6 R Servo question.
I have my trans out because of a 2/3 shift flair that was getting bad. The pan had just alittle bit of black material in the bottom like what someone would put pepper eggs. My question is how tight should the R servo be to move in the bore? I cant pull it out with my fingers, I have to some leverage to get it out. Should it be this tight?
airford1- Posts : 192
Re: C6 R Servo question.
the spring should pop it out of the bore in the case ,if not it's too tight!!! and don't use the sonnax springs as there to light ,use a stock Ford spring with .135" or thicker wire
Frank Merkl- Posts : 1524
Thanks Frank. I found a Valve body are you ready to stop working outside?
Turned down the servo and replaced the spring, changed the A lever to an E, also found a problem with my valvebody. WHHHHOOOOO HAAAAAWWWWW, were back to burnin rubber. Thank Frank.
» C6 servo question
» Sonnax Servo Modifying question
» C6 H Servo
» C6 Problem... Please Help
» Why is my c6 servo like this?
» C6 H Servo
