HOW to Fill A block?
mikey hefner
powerstrokeace
OK so I'm building a stock block 557. So i have the Hard Block filler and i'm wanting everybody's input here. This is only a fill to the lower water pump holes
1) torque the main bolts
2) level one side of the block
3) once the mixture is completed fill the block through the water jacket holes
Now this is were i get confused. do you install torque plates or not? and let it harden up.
after all this then bore and hone the block to desired size
Ace
Ace
powerstrokeace- Posts : 1496
Re: HOW to Fill A block?
Installing the torque plate won't hurt IMO
block filling
About to go threw this myself, I don't have access to torque plates . Will I be ok without them?
mikey hefner- Posts : 79
could you just bolt the Heads on in place of the torque plates
Ace
Ace
Yes, but I've seen them filled with out too. BBF don't distort much if any with the heads on.
How about digesting all the scale and cleaning/prepping/etching the water jackets thoroughly prior to the pour? Some people use muriatic acid (last paragraph in the link below):powerstrokeace wrote:OK so I'm building a stock block 557. So i have the Hard Block filler and i'm wanting everybody's input here. This is only a fill to the lower water pump holes
Ace
http://www.network54.com/Forum/85220/message/1034207213/Here+are+some+block+filling+tips---
Paul
I did the mutatic acid deal to clean any scale out of my block prior to fill, then flushed and blew the block out to make sure it was clean and dry. Then like you are planning, torqued the main caps, leveled one side up and poured a little through several of the holes to fill. Just make sure you give the block a little vibration action while pouring to make any trapped air come out. After it's filled to where you want, clean off any spills before it sets and wait until it's firm. Flip to the other side and do the same. I didn't use the torque plates until I bored/honed the block and had no issues. We also put the block in a curing oven to make sure the concrete was fully cured prior to doing any machine work just to be safe.
kjett- Posts : 1169
Level the block, fill through the water passages moving back and forth. Use an air hammer to vibrate the block. Use a piece of rod to help move the " mud" around. Let it sit a couple days and do the other side. Then off to to the machine shop to finish machining
mico- Posts : 33
Hey mike I need to talk with you some time very soon. What are you doing Thursday? Are you here or Vegas
Ace
Ace
blocks filled and ready for the machine shop. just waiting on pistons. it will now be a 557 stroker with completely update port work on the old Motorsports A460 heads for a back up motor
Ace
Ace
Not bad for a backup motor.
460pulling- Posts : 249
Are you putting it in the digger or a new project?
Dave C.- Posts : 1268
For right now it plan is a back up motor. I broke a 514 last April and I had enough stuff less piston to build this. We are also thinking of another car/trailer deal but we need something more than a grudge car for what the ultimate goal it here.
I'm also planning another build with slightly better parts and a set of new style A460 heads and bigger cubes
Ace
Ace
» To Fill Or Not To Fill
» 4.390 and a block fill?
» fill o ring grooves in block
» Are there two diffrent size front pumps for c4 pan fill and case fill ?
» Building a c-4 for a 408
