Front planetary scaring
It appears that in a previous life my tranny spun the locating tabs off the thrust washer for the front planetary and there is a fair amount of scaring. Question is: I bought a forward hub from broader that utilizes a Torrington bearing between the forward hub and front planetary....will it be ok for the Torrington bearing to rest on this scored surface, or do I need a new front planetary?
If I were going to stick with the thrust washer I feel like it would be ok to re-use the planetary because the non-moving side of the thrust washer sits on the planetary.
Would you guys run this planetary with the roller bearing or get a new planetary?
Thanks again,
Jon
Thanks again,
Jon
460bronco- Posts : 364
Re: Front planetary scaring
If the surface is flat enough (no massive trenches it looks like) for support for the bearing, it should be fine. So, is the hub cut for a bearing pocket then?
J.Toney- Posts : 398
Yep the clearance was added in the hub. I ended up taking a spare c6 that I had apart and found a mint front planet in it, so it will be utilized in the current build.
