New best
+6
dirt_worker
quick 52
Dave C.
tfsbbf466
10 posters
New best Empty New best
Post  tfsbbf466 October 26th 2013, 6:32 pm
I installed a new converter a few weeks ago and it picked up some mph and I just installed a new cam from Blake. Went to the track and got a new best on motor 11.25 117 even with the tighter converter. Then put the bottle to it. First pass was a 10.12 129 and I was like we are on to something here. Few more passes quickened up the progressive and added 2 degrees of timing I netted a best of 10.05 129. I wanted a 9 badly so I put an 82 jet in an took 4 more degrees out and bam 9.98 130.13. Very happy that I finally achieved my goals of single digits as well as 130mph and a 1.3 60ft. Best 60ft of 1.36. This was all done on pump gas and drag radials with a 4000lbs leaf spring truck driven to and from the track.
tfsbbf466
New best Empty Re: New best
Post  res0rli9 October 26th 2013, 6:41 pm
Cool Cool Cool
Post  Dave C. October 26th 2013, 6:58 pm
Congrats!
Dave C.
Post  quick 52 October 26th 2013, 11:29 pm
that's getting it done big time... you got me thinking of building 521... I just got into the 10s with a best of 10.81 but think it if all the star's align there a 10.50 in it... Great pass and driving to and from the track is even cooler with those ET
quick 52
Post  bbf-falcon October 27th 2013, 2:42 am
Cool Cool Cool Congrats
Post  dirt_worker October 27th 2013, 8:37 am
I'm impressed!
Hope mine will do 1.30s and 9something on radials and pumpgas.
Approx hoe much juice is an 82 jet?
dirt_worker
dirt_worker
Post  quick 52 October 27th 2013, 9:35 am
82 jet is 200-225 hp
quick 52
Post  bluef100fe October 27th 2013, 10:43 am
Congrats... you really make me wanna spray mine.... with everything you got goin on there that's a hell of a accomplishment... gonna put a cage in it yet?
bluef100fe
bluef100fe
Post  tfsbbf466 October 27th 2013, 1:00 pm
Thanks guys. Yeah 82 is around 200-225. It went 10.05 on a 73 jet which is around 175. It picked up less then a tenth and 1mph with the bigger jet but enough to get my single digit pass. I still have an 850 carb and 1 7/8 headers so it's possible I'm maxed out between those 2. Track prep was awesome but the way the converter works it almost bogs the motor down the harder you leave with it so it allows the torque to push the truck without blowing the tires away. My best 60ft before that was a 1.43.
Quick 52: I went 10.38 with my 466 so you definitely have mid 10s in your set up
tfsbbf466
Post  quick 52 October 27th 2013, 2:25 pm
I need to find the right stall for mine right.. with this 700 trans and a 3.06 first gear if the track isn't great my 60' are not there
quick 52
Post  tfsbbf466 October 27th 2013, 3:12 pm
That's a big problem. What is your rear gear and tire size? I'm 3.70s 29.5" tires and a 2.46 1st gear.
tfsbbf466
Post  quick 52 October 27th 2013, 4:37 pm
tfsbbf466 wrote:That's a big problem. What is your rear gear and tire size? I'm 3.70s 29.5" tires and a 2.46 1st gear.
running 315x60x15 mt dr they r 30" and a 3.89 4500 stall want to get a 3600 stall
quick 52
Post  tfsbbf466 October 27th 2013, 7:53 pm
I'm running the same tire. PTC told me 3800 on motor and 4200 on spray. I assume it's close to that and it has helped my truck leave a lot harder. Your tall first gear and rear gear will be tough to get to work consistently so I'm told. I may end up going to 3.50s
tfsbbf466
Post  airford1 October 27th 2013, 9:40 pm
Bad to the BONE.
airford1
airford1
Post  whitefield October 27th 2013, 9:43 pm
Great job! Do you have any video or pics of your truck ?
whitefield
whitefield
Post  Mark Miller October 28th 2013, 1:54 am
whitefield wrote:Great job! Do you have any video or pics of your truck ?
X2,Pictures would be great if you have some.
Thanks Mark.
