season change
season change Empty season change
Post  quick 52 October 28th 2013, 9:56 am
With the season change have time to work on the truck need to work on suspenion. the rear shock location where is the best in front of axle or behind straight up and down or angle leaf spring truck
quick 52
season change Empty Re: season change
Post  bluef100fe October 28th 2013, 10:06 am
I remounted mine behind the rear axle... there is more spring flex/movement behind the axle than in front of it. Makes more sense to me to have the shock on the end of the spring that has the most motion when the axle is separating/compressing from the chassis... really like your truck. Have fun
bluef100fe
bluef100fe
Post  460bronco November 3rd 2013, 8:06 pm
The farther from the pivot point, the more dampening ability the shock will have due to lowered mechanical advantage of the suspension motion over the shock. When the shock is mounted parallel to the direction of motion the shock has the greatest dampening ability. If you put them on an angle- ex. 45 degrees, then the shock would have half the dampening ability as it did when mounted vertical. Basically changing the location or angle will just change how soft or stiff the shock seems.
460bronco
460bronco
Post  quick 52 November 3rd 2013, 8:43 pm
here are a couple pic
season change DSC06025_zpsc603e448
season change DSC06027_zps3d6ff6fb
season change DSC06024_zps6ba15364
season change DSC06023_zps7c9e5e00
season change DSC06022_zps1ce84242
season change DSC06007_zps25a83b3e
quick 52
