Testing tomorrow and Sunday - 300 shot
+10
yellowhorse7
psfracer
14 posters
Testing tomorrow and Sunday - 300 shot Empty Testing tomorrow and Sunday - 300 shot
Post  psfracer November 1st 2013, 7:53 pm
Testing tomorrow and Sunday at Famoso. Going to see if the changes I made will allow me to 60' in the 1.25s consistently. Going for some 8.50s in the 1/4 as well.
If Saturday goes as planned, I am going to try a 300 shot on Sunday and do some 1/8th mile passes. Hopefully high 5.3Xs. After looking at the plugs, some full 1/4 mile passes after that. My best on the 200 has been a 5.56.
This motor has been running great for 2 1/2 years, time to lean on it some.
I've got 3 go-pros and my bro on the camcorder, so I should get some good vids.
Testing for SCSN9 in Vegas on 11/14-11/17.
Testing tomorrow and Sunday - 300 shot PaulTopDogShootoutWeb
Testing tomorrow and Sunday - 300 shot 994591_490434397722291_1805008186_n
psfracer
psfracer
http://www.psfracer.com
Testing tomorrow and Sunday - 300 shot Empty Re: Testing tomorrow and Sunday - 300 shot
Post  the Coug November 1st 2013, 8:45 pm
If you by chance see Les tomorrow tell him Jon (Fabio) said he misses him.....Razz
Post  69F100 November 1st 2013, 8:59 pm
Good luck be safe and hope you hit the 5.30s
Post  yellowhorse7 November 1st 2013, 9:00 pm
Creep up on it. Don't hurt stuff.
If all goes well you should run your number. I've been there with my junk and you have MUCH more than me
yellowhorse7
yellowhorse7
Post  psfracer November 1st 2013, 9:03 pm
Yeah definitely going just to the 1/8th first.   If time allows I am going to try a 250 first on Saturday afternoon.  I run a 200 now on 22 degrees of timing with VP NO2 120 fuel--but a very conservative 2 spread on fuel/nitrous. 5 3/4 lbs fuel pressure.
psfracer
psfracer
Post  Lem Evans November 1st 2013, 9:20 pm
That's one pretty Mustang ....good job Very Happy
Post  psfracer November 1st 2013, 9:25 pm
I still can't believe how much it picked up after you did the heads. 9.41 to a 9.16.
I bet it would pick up more if I put a bigger carb on it to.
psfracer
psfracer
Post  Lem Evans November 1st 2013, 9:30 pm
Charlie did the heads but I can help you in the carb. department if you wish.
Post  psfracer November 1st 2013, 9:38 pm
Oh yeah, silly me.
I will PM you about the carb and get your thoughts on what I need. I didn't realize you sold carbs.
psfracer
psfracer
Post  Lem Evans November 1st 2013, 9:49 pm
1] Big compression
2] Fast burn chamber
3] 10 head bolts
I think you should evaluate your piston to head distance & consider a cam change when you go to 300 shot and above.
Be carefull with the timing also.
Post  richter69 November 1st 2013, 10:22 pm
pull a little more timing and put more spread in it, 2 numbers sounds fat.
you got my number Ill be around all day.......
Post  richter69 November 1st 2013, 10:36 pm
the Coug wrote:If you by chance see Les tomorrow tell him Jon (Fabio) said he misses him.....Razz
Testing tomorrow and Sunday - 300 shot 022375AB-2450-4E9C-8AFF-6C9A2ED03C81-440-00000261EF132BDD_zps8ab3581e
Post  IDT-572 November 1st 2013, 10:59 pm
The Dynamic Duo................. With Bruno bringing up the rear:shock: Razz
Post  dfree383 November 2nd 2013, 12:09 am
IDT-572 wrote:The Dynamic Duo................. With Bruno bringing up the rear:shock: Razz
He said "Rear"......Laughing Laughing Laughing
Post  psfracer November 2nd 2013, 12:56 am
Party at Famoso!!!!!
Ok I will make sure he gets the message. I love you I love you I love you I love you
psfracer
psfracer
Post  dfree383 November 2nd 2013, 1:10 am
Whooooot Whoooooot ! Laughing
Post  cool40 November 2nd 2013, 8:23 pm
update
Cool
Post  psfracer November 3rd 2013, 1:37 pm
Just ran a 8.579 @ 158.78 with a 1.272 60' and an 1/8th of 5.495@ 127.15 mph.
250 shot, still conservative with a 4 spread, 5 3/4 psi, 20 degrees timing.
psfracer
psfracer
Post  richter69 November 3rd 2013, 1:44 pm
more spread!!!!
Post  yellowhorse7 November 3rd 2013, 11:39 pm
richter69 wrote:more spread!!!!
Like 6-8 more
yellowhorse7
yellowhorse7
Post  psfracer November 4th 2013, 11:54 am
So no trips needed to the Hero parts trailer yesterday, and I always say that is a good thing.
Ok, so here is the deal:
The Saturday runs were just my "baseline" runs as I wanted to see the difference my changes made on the following day, Sunday. So on Sat I ran two 8.75s @ 156 mph.
Sunday: I changed the tune up as follows: OLD tune up was 26 N20 jet, 24 Fuel Jet, 7 psi fuel, 22 degrees timing. Was too rich, leaned it up a bit to a 28 N20 Jet, same 24 fuel jet, reduced fuel psi to 6 psi on the N20 regulator, and backed off the timing to 20 degrees. Car responded with the 8.579 @ 158.78 with a 1.272 60' time.
Still showing a little rich. Stayed with same 28 N20 jet, changed fuel jet to 22, kept fuel pressure at 6psi, timing 19 degrees. I could tell the car liked that even more, but unfortunately it blew the tires off, so its making some power.
I also ran a 8.66 @ 157 but my bottle pressure was way low on that pass as there was a delay on the track and I was in the staging lanes a long time.
Anyway--I am going to stick with the 250 shot and continue to refine the tune, as I am noticing the engine responding to minor changes in a big way. Also, the car will be hitting the limiter through the stripe at 160, so perhaps a little taller tire or a slight gear change is in order. In any case not worried about it right now as my cage is only good to 8.50 anyway, and I think by continuing to refine the tune I will reach 8.50.
Video. There is always video. Video of my best pass:
psfracer
psfracer
Post  windsor November 4th 2013, 12:12 pm
You make cool videos...and cool cars!
Post  scottke November 7th 2013, 10:30 pm
Minitubb job looks killer. Good pass.
scottke
scottke
Post  psfracer November 8th 2013, 2:02 am
Thanks!  I really think this thing has a high 5.3X in it for the 1/8th.  I am running out of gear for the 1/4, I don't see me going any higher then 160 on the mph though in the cars current configuration.
psfracer
psfracer
Post  Dave C. November 8th 2013, 6:37 am
Nice job.
Dave C.
