stock crank ?s
466cj
bluef100fe
mitch
stock crank ?s
are the internal balance cranks any better than the external balance cranks for high rpms? at what point should i consider upgrading to a forged crank? this would be in a pulling engine
mitch- Posts : 116
Re: stock crank ?s
The factory cast cranks are some really good pieces, and would be able to handle about anything you can throw at them. What block are you going to use?
schmitty- Posts : 4538
Re: stock crank ?s
Define high rpm...
Re: stock crank ?s
Depends on a bunch of things... but I got a Adney brown prepped oem cast crank in a 472 inch pulling engine and it routinely sees 8600-9000 rpm... haven't had anything bad happen yet... knock on wood...
bluef100fe- Posts : 379
Re: stock crank ?s
over 7,000 RPM I'd prefer an internal balance crank, but am sure some have made the external work. Personally I like the internal cranks simply because I prefer not have to deal with balance weights on a flywheel.
466cj- Posts : 391
Re: stock crank ?s
You can take the late model crank and internally balance it, the weight isn't in the counter balances as provided, BUT, with high performance parts the counter weight is extremely less than stock anyhow.
I had to cut 3lbs out of my billet crank before I could even start balancing it. Nothing turning the counter balances down a few inches couldn't handle. BUT... it does tell that new high performance bolt on parts might make the stock crank internal balance with very little Mallory at all.
kim- Posts : 700
Re: stock crank ?s
The ONLY differences between an INTERNAL balance OEM crankshaft and an EXTERNAL balance OEM crankshaft is the rear oil "slinger" diameter and the diameter size of the counterweights. SOME have a different diameter torque converter recess as well.
The metallurgy is exactly the same.
Re: stock crank ?s
I would like to use the block and crank from my '97 F350 if possible.schmitty wrote:The factory cast cranks are some really good pieces, and would be able to handle about anything you can throw at them. What block are you going to use?
7,000-8,000.cool40 wrote:Define high rpm...
mitch- Posts : 116
Re: stock crank ?s
If you are going to spin it that high, a 4 bolt main block would be a good idea, and priority main oiling. The crank will not be the weak point.
Re: stock crank ?s
7000 is one thing,8000 is another.i'd go with a good block and crank.JMO
![Smile](https://2img.net/i/fa/i/smiles/icon_smile.gif)
Re: stock crank ?s
8000 wasn't super expensive..... 9000 was a whole new world for us.... but the truck works there... we will continue to go there until we can't afford to... or the class dies out.... internally balanced with light parts up top... fun stuff for sure...
Re: stock crank ?s
the key subject here is "pulling engine".........pulling=run the hell out of
![affraid](https://2img.net/i/fa/i/smiles/affraid.gif)
Re: stock crank ?s
I have to use cast iron intake, heads and exhaust. I don't know for sure how high it will be able to rev, I've heard others in the class run in the low 7000's.
mitch- Posts : 116
Re: stock crank ?s
If I read it right ... Cody's 8,600 to 9,000 RPM engine is also a "PULLING" engine.cool40 wrote:the key subject here is "pulling engine".........pulling=run the hell out of![]()
EDIT: Personally, I have used an OEM, offset ground, cast nodular crank in a 1,200 horsepower drag boat engine for 3 years untill it finally showed some fillet cracks.
Last edited by rmcomprandy on November 20th 2013, 12:45 am; edited 2 times in total
Re: stock crank ?s
you'll have no problem with stock crank and block with those rules.mitch wrote:I have to use cast iron intake, heads and exhaust. I don't know for sure how high it will be able to rev, I've heard others in the class run in the low 7000's.
![Cool](https://2img.net/i/fa/i/smiles/icon_cool.gif)
Re: stock crank ?s
yep,i missed that.guess the big truck pic with the wheels knee high cought my eye.rmcomprandy wrote:If I read it right ... Cody's 9,000 RPM engine is also a "PULLING" engine.cool40 wrote:the key subject here is "pulling engine".........pulling=run the hell out of![]()
![Laughing](https://2img.net/i/fa/i/smiles/icon_lol.gif)
Re: stock crank ?s
Our stock truck pulling classes have those kinds of rules... we are running in the low/mid 7000's seems we hit a limit with the stock rocker arms... the push rods were piercing the rocker arms at anything over about 7300 rpm... this was a 466 with solid flat tappet cam cj intake and PI exhaust manifolds.... vacuum secondary carb and a set of dove heads... damn thing still runs good to this day... as for the blue polebilly pickup truck... I never thought it would carry the tires and still be streetable... its pretty slow but still a fun ride on the street... thanks again to rick brown for the pictures again... I never get sick of seeing this picture...
Re: stock crank ?s
I will be doing almost exactly the same thing but i would use roller cam and rockers.bluef100fe wrote:Our stock truck pulling classes have those kinds of rules... we are running in the low/mid 7000's seems we hit a limit with the stock rocker arms... the push rods were piercing the rocker arms at anything over about 7300 rpm... this was a 466 with solid flat tappet cam cj intake and PI exhaust manifolds.... vacuum secondary carb and a set of dove heads... damn thing still runs good to this day
mitch- Posts : 116
Re: stock crank ?s
Then the weight of your valves/valvetrain will be your limiting your rpms to 8000.... we were breaking rocker studs at that rpm with the heavy stainless valves.... after that we went to shaft rockers and titanium valves.... our stock class rules mandated non roller rockers and lifters.... good luck with your adventure... pulling is just as addictive as any other Motorsports...mitch wrote:I will be doing almost exactly the same thing but i would use roller cam and rockers.bluef100fe wrote:Our stock truck pulling classes have those kinds of rules... we are running in the low/mid 7000's seems we hit a limit with the stock rocker arms... the push rods were piercing the rocker arms at anything over about 7300 rpm... this was a 466 with solid flat tappet cam cj intake and PI exhaust manifolds.... vacuum secondary carb and a set of dove heads... damn thing still runs good to this day
crankshafts
I guess this is a hijack-- but what kind of diam. difference is there in slingers between the two?
Perry
Perry
hpwdboss1- Posts : 147
Re: stock crank ?s
Just about a half inch.hpwdboss1 wrote:I guess this is a hijack-- but what kind of diam. difference is there in slingers between the two?
Perry
Re: stock crank ?s
Badass.rmcomprandy wrote:...Personally, I have used an OEM, offset ground, cast nodular crank in a 1,200 horsepower drag boat engine for 3 years untill it finally showed some fillet cracks.
Re: stock crank ?s
I just finished executing our Stage 1 Oiling Mods to a D9TE-AB block for a customer, and he also needed the block prepped to accomodate his 2Y Series internal balance crankshaft. And so I went into our inventory and pulled out 3 crankshaft cores for rear slinger comparison: The 2Y series, the 3Y Series, and the commercial 429 steel truck crankshaft. Here's what I observed:hpwdboss1 wrote:I guess this is a hijack-- but what kind of diam. difference is there in slingers between the two?
Perry
![stock crank ?s 2ya](http://home.earthlink.net/~kaneofthenation/sitebuildercontent/sitebuilderpictures/2ya.jpg)
![stock crank ?s 3ya](http://home.earthlink.net/~kaneofthenation/sitebuildercontent/sitebuilderpictures/3ya.jpg)
![stock crank ?s D9te-6303](http://home.earthlink.net/~kaneofthenation/sitebuildercontent/sitebuilderpictures/d9te-6303.jpg)
Remember, these are very high volume, mass production parts, so your exact dimensions may vary.
I think that just turning the slinger down to the seal riding diameter is fine, that's how the Scat crankshafts currently are.
Paul
» 302 stock crank
» Stock 429 crank
» Strength of stock crank on NOS
» What is a stock Forged Crank worth
» Scat 9000 vs stock crank
» Stock 429 crank
