pinion angle
pinion angle
88 t bird fox body solid bushings in the rearend housing and hiem joint double adjustable upper and lower bars. what should I use as a starting point for pinion angle?
Thanks,
Steve
Thanks,
Steve
70429scj- Posts : 348
Re: pinion angle
Very little is needed. -1 to -1.5 should be good.
whatbumper- Posts : 3024
Re: pinion angle
Just make sure you don't have a wonky U-joint operating angle at the front (driveshaft to slip yoke) & the mentioned rear pinion U-joint operating angle of -1.0 to -1.5 should be good to go.
DILLIGASDAVE- Posts : 2262
Re: pinion angle
Good pointDILLIGASDAVE wrote:Just make sure you don't have a wonky U-joint operating angle at the front (driveshaft to slip yoke) & the mentioned rear pinion U-joint operating angle of -1.0 to -1.5 should be good to go.
» Drive Shaft angle vs Pinion angle
» pinion angle?
» Pinion angle?
» Pinion Angle ?
» Spoilers what angle?
» pinion angle?
» Pinion angle?
» Pinion Angle ?
