NEW BBF BILLET HEADS!
+20
Nightmare AA/FA
QtrWarrior
Outlaw5.0
gordyd4
79Puller
curleysracecars
Gary Blair
Bret Powell
Wheelie58
bigblok2000ranger
powerstrokeace
dtimmer
24 posters
Page 1 of 3 1, 2, 3  Next
NEW BBF BILLET HEADS! Empty NEW BBF BILLET HEADS!
Post  dtimmer December 7th 2013, 2:19 pm
Here is a sneak peak at our new bbf billet head. These have the standard head bolt pattern (18 bolt), and use standard lifter locations. The use our custom individual rockers stands (multiple bolts per stand) with all on center rockers (Jesel or T&D). The are available in solid form (no water) or with water jackets.
They will be on display at PRI. Booth 6128
NEW BBF BILLET HEADS! 1
NEW BBF BILLET HEADS! 2
NEW BBF BILLET HEADS! 3
NEW BBF BILLET HEADS! 4
NEW BBF BILLET HEADS! 5
NEW BBF BILLET HEADS! 6
dtimmer
http://www.visnerengine.com/
NEW BBF BILLET HEADS! Empty Re: NEW BBF BILLET HEADS!
Post  res0rli9 December 7th 2013, 2:24 pm
Nice Cool
Post  Lem Evans December 7th 2013, 2:28 pm
Is that Craig Sullivan's stuff?
Post  dtimmer December 7th 2013, 2:30 pm
Edit.
Yes they are for craigs new engine.
dtimmer
Post  Lem Evans December 7th 2013, 2:43 pm
dtimmer wrote:No. This is our own stuff. All designed and machined in house. Visner Engine Development, Lowell, Michigan
I did not say Craig made it. I was wondering if Craig is the end user.
Post  Lem Evans December 7th 2013, 2:44 pm
dtimmer wrote:Edit.
Cool
Post  dtimmer December 7th 2013, 2:49 pm
Yea my fingers typing worked faster than my brain for that post. Took a minute for the name to register lol
dtimmer
Post  schmitty December 7th 2013, 3:00 pm
Can you elaborate more, like suggested CI, bore size, flow, etc.?
Post  jbozzelle December 7th 2013, 3:07 pm
Always been curious... How do you get water passages in a billet head? Mill the passages from the bottoms and ends then plug the ends?
Post  dtimmer December 7th 2013, 3:25 pm
schmitty wrote:Can you elaborate more, like suggested CI, bore size, flow, etc.?
Not really. Each head is tailored to the customers wants/needs. In this case the head is designed for big bore (4.650+) and big inches (700+).
The beautiful thing about billet is you can change anything you want with a simple drawing change. You want a 4.500 bore, sure why not. We have many port designs for many different applications. N/A, nitrous, turbo, ect. The basic design stays the same and finishing touches are added to fit the customers application.
I can tell you this, with similar port designes on a 5.0 borespace "BBC" @ 650" it made 1530hp
dtimmer
Post  dtimmer December 7th 2013, 3:31 pm
jbozzelle wrote:Always been curious...  How do you get water passages in a billet head?  Mill the passages from the bottoms and ends then plug the ends?
Water passages are gun drilled from the ends, the deck, and other locations to pull heat out where it needs it, the ends of the holes are plugged. They are setup for reverse flow and works very efficiently.
dtimmer
Post  powerstrokeace December 7th 2013, 10:15 pm
I thouhgt these are Holbrook (spelling) heads
Ace
powerstrokeace
powerstrokeace
Post  bigblok2000ranger December 7th 2013, 10:26 pm
Look good Darek, you need a set for your Mustang! Wink
bigblok2000ranger
bigblok2000ranger
Post  Wheelie58 December 8th 2013, 7:24 am
I will have to stop by and take a look. They look great.
Keith
Wheelie58
Wheelie58
Post  Bret Powell December 8th 2013, 10:22 am
Looks a lot like an E head. Except of course for the bolt pattern. How far off an E head is it in port shapes and configuration?
Bret Powell
Post  Lem Evans December 8th 2013, 12:20 pm
powerstrokeace wrote:I thouhgt these are Holbrook (spelling) heads
Ace
Holbrook is Craig's engine guy......Visner made the heads.
Post  c.evans December 8th 2013, 2:45 pm
Nice looking head. I'm not seeing any provision for oil return or drainback. Why?
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  dtimmer December 8th 2013, 4:01 pm
There is. One on each end, in the corner above the head bolt. They are external drain backs.
dtimmer
Post  c.evans December 8th 2013, 5:07 pm
I'm just guessing here, but I assume the incline angles are somewhere between 8* and 12*. Looks like the cant angle is maybe 4.5*-5.0* on the intakes and 3.0*-3.5* on the exhausts.?? What size valves?
I see that you haven't machined the holes for the innermost 4 head bolts/studs yet. To the best of my knowledge they are angled towards the intake manifold 7.5* off of perpendicular to the deck. I have had to correct some from other manufacturers. They went 7.5* the wrong way when the head was upside down.
Do you know how much offset is required in the intake lifters yet?
Again, very nice head.Cool
Charlie Evans
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  dtimmer December 9th 2013, 10:05 pm
Yea your pretty close on the valve angles. Id have to pull up the drawing to figure out for sure. We have been busy gettingbready for the show, i cant remember exactly on the valve size. But i believe it is 2.520 on the intake. I'll have more info together at the show if you stop by.
I havent gotten a chance to machine the inners yet. My fixture was in the way on my 5 axis to drill them, gotta make a new one. I,ve had to fix a few of those also Wink
Thanks for the compliments guys, id really like to get some more of these out there to see what they are capable of. After craig makes some passes with them maybe more will be interested. I've always been a BBF fan, so im pushing to make more!
dtimmer
Post  dtimmer December 9th 2013, 10:08 pm
As for the lifter offset: .150 on intake and exhaust.
We have another version that uses relocated lifters to optimize the pushrod geometry, but this design turned out better than expected. Far better than the thors or C head.
dtimmer
Post  Wheelie58 December 13th 2013, 11:14 pm
I actually got to touch these heads. Very nice metal art .
Keith
Wheelie58
Wheelie58
Post  Gary Blair December 14th 2013, 11:12 am
dtimmer wrote:As for the lifter offset: .150 on intake and exhaust.
Great looking head!
Gary Blair
Gary Blair
Post  curleysracecars December 15th 2013, 11:55 pm
Dave Visner and the guys are a great people, who turn out some excellent products! Glad to see the BBF stuff guys. Keep up the good work.
curleysracecars
curleysracecars
http://www.curleysracecars.com
Post  dtimmer January 16th 2014, 5:22 pm
NEW BBF BILLET HEADS! Sullivan1
NEW BBF BILLET HEADS! Sullivan2
dtimmer
