C Headed, 610 C. I.
C Headed, 610 C. I. Empty C Headed, 610 C. I.
Post  Art December 9th 2013, 4:15 pm
610 ci BBF, A-460 block, C heads with T&D rockers, 1.7 ratio, (spares), Manton pushrods, spare set of trick flow push rods, Crane roller lifters,  titanium intake valves, Inconel steel exhaust valves, Manley springs,  diamond pistons (1 spare), coated tops and sides, tool steel rings, GRP pro series nitrous rods, roller cam bearings, Calles crank, ATi super dampener,  Jeff Johnston oil pan with external mount stock car products oil pump, remote mount oil filter with system 1 filter, custom made front exit headers, C&S water pump, MSD crank trigger and crank trigger distributor, custom Bullet cam shaft, Danny Bee belt drive, A-460 matching intake that has been port matched to heads. Head and intake gaskets are cometic, Pro Systems 1450 CFM carburetor built for this combination. ARP head studs, and arp intake bolts. Heads originally ported by Charlie Evans. Reworked by Mike Curcio of M.C. R.P. Short block assembled by Tim Knieriem of Knieriem Racing Engines. $14,500.
Has a NX fogger system. It was flowed and plumbed by Kevin Neal of JuneBug Nitous. Motor has about 20 1/8 mile passes. It has been a best of 5.13 at 142 mph with a very soft tune up in a 3350 lb car. If any interest also can be turn key. Car is a 98 Mustang. Getting out of racing, don't have the time or money to do it. We know there is a lot of potential left in this set up. Little time to test.
Thanks for looking.
Art
812-989-4903
Art
C Headed, 610 C. I. Empty FRT. EXIT HEADERS
Post  mbrucestang December 12th 2013, 4:58 pm
I AM INTERESTED IN HEADERS, IF YOU WANT TO SELL SEPERATELY ? I HAVE 87 NOTCHBACK MUSTANG WITH C 460 HEADS, CAN YOU SEND PICS.
mbrucestang
C Headed, 610 C. I. Empty Re: C Headed, 610 C. I.
Post  mikey hefner December 13th 2013, 12:08 am
I wish I had the funds, I'd love to have it!! Good luck with the sale!!!
mikey hefner
Post  Art December 13th 2013, 8:40 am
mbrucestang wrote:I AM INTERESTED IN HEADERS, IF YOU WANT TO SELL SEPERATELY ? I HAVE 87 NOTCHBACK MUSTANG WITH C 460 HEADS, CAN YOU SEND PICS.
I can send picutres of headers mounted on motor as it sets in the car. I am not interested in the selling the headers separately unless some buys the motor and doesn't want them. What is is email?
thanks for looking
Art
Post  DNETT1727 December 13th 2013, 10:59 pm
I would love the short block if you would like to separate the motor out
DNETT1727
DNETT1727
Post  Art December 14th 2013, 6:45 pm
DNETT1727 wrote:I would love the short block if you would like to separate the motor out
Would like to sell from carb to pan as it is. No vacuum pump is included.
Art
C Headed, 610 C. I. Empty 610 bore size
Post  fairlanegt66 December 15th 2013, 9:43 am
what is bore size of 610 motor?
fairlanegt66
Post  Art December 15th 2013, 1:01 pm
fairlanegt66 wrote:what is bore size of 610 motor?
Don't recall off hand. I will check the specs, which are at the shop.
Art
C Headed, 610 C. I. Empty 610 specs
Post  fairlanegt66 December 15th 2013, 5:54 pm
let me know when you have detailed specs. thank you
fairlanegt66
