What oil pan ?
What oil pan ? Empty What oil pan ?
Post  79Puller December 10th 2013, 7:41 pm
What oil pan do I need to run on a 460 that is going into a 2wd 79 Ford F-150 ? Thanks
79Puller
What oil pan ? Empty Re: What oil pan ?
Post  supervel45 December 10th 2013, 8:35 pm
I would locate a 1973-79 rear sump pickup truck pan, and oil pump with pickup. I used a front sump car pan on my 1978 and installed a new drain plug, the stock plug was on the croosmember and could not be removed. Another problem is the car pan cannot be removed with the engine in the vechicle, if need be. If you want after market Milodon is good. Also Morso is a lttle cheaper, but the pans seem thinner.
Post  res0rli9 December 10th 2013, 9:33 pm
BBF Fox oil pans will also work.
Post  79Puller December 10th 2013, 9:59 pm
So a rear sump and not a front sump is what I should look for. Thanks I had it backwards I thought I needed a front sump.
79Puller
Post  460pulling December 10th 2013, 10:42 pm
I have mounts stands and the stock pan and pick up. If that's what your hunting.
460pulling
Post  69F100 December 11th 2013, 1:01 am
79Puller wrote:So a rear sump and not a front sump is what I should look for. Thanks I had it backwards I thought I needed a front sump.
You can use either one but the front sump make a mess when changing oil  Mad  like was said if you use a front sump move the drain plug to the back of the sump
