New cylinder heads
+20
Captainp4
steven gregoire
AL Q
557ranger
lghting94
BigRigTech
QtrWarrior
sg86coupe
Gary Blair
Wheelie58
5pointslow
GT300TD
24 posters
Page 2 of 2 Previous  1, 2
New cylinder heads - Page 2 Empty Re: New cylinder heads
Post  Wheelie58 December 20th 2013, 12:57 pm
Could have at least got the KFM sign in the background
Wheelie58
Wheelie58
Post  schmitty December 20th 2013, 1:12 pm
HorsinAround wrote:He told Branden and I $2100 with seats and bronze guides inserted. I don't profess to be a head porter but from what little I know, these heads have huge potential. I'd say close to 500cfm.
Mike said $2300 for the A intake/ BBC exhaust, and $2100 for the CJ intake/BBF exhaust. Both configurations have a standard valve layout. He is also going to do a few sets with CJ intake/ BBC exhaust, similar to the old Blue Thunder B head. All I know is that there will be a lot of pullers and mud drag guys who finally have a set of heads that fit their needs.
Post  BigRigTech December 20th 2013, 1:39 pm
Those pullin' guys are gonna be pullin' something when they see these pics.  lol!   ....They look pretty hefty too, some blue paint and your going to fool a lot of people unless they know what they are looking at.
BigRigTech
BigRigTech
Post  HorsinAround December 20th 2013, 1:57 pm
Wheelie58 wrote:Could have at least got the KFM sign in the background
Very Sorry Keith, next year I'll do better I promise.. I was doing good to get steady shots of the heads because my heart was still racing from the activity at the booth I was at just before we came to yours..... Travis was having trouble operating the camera on my iphone, so I got to hang on a little longer than usual..  Twisted Evil
New cylinder heads - Page 2 IMG_0943_zpsc31de4c2
http://www.frontpagefab.com
Post  HorsinAround December 20th 2013, 2:02 pm
hopefully these heads will not only fill the void now that the ex514 heads aren't being produced but also go beyond.
Post  lghting94 December 20th 2013, 2:29 pm
Best I remember the ex-514's were around 100 pounds each so if these are that or less that's good. Having any aftermarket iron head will help a lot of guys trying to compete in the all iron classes.
lghting94
lghting94
Post  schmitty December 20th 2013, 2:36 pm
Todd, these heads are well under 100#. They are similar in weight to a stock head.
Post  lghting94 December 20th 2013, 2:40 pm
If that's the case that is another advantage because bbc heads are very heavy also. Only problem I am seeing with them is they are coming out about three years to late I no longer need them.
lghting94
lghting94
Post  schmitty December 20th 2013, 2:49 pm
It's never too late to get back in again.  Very Happy
Post  HorsinAround December 20th 2013, 2:57 pm
schmitty wrote:It's never too late to get back in again.   Very Happy
I told my wife that, and she mentioned the "D" word if I built another pulling truck....
Post  cool40 December 20th 2013, 2:58 pm
If the weight aint too big a deal in a build I'd take iron over aluminum. They tend to stay put better.
New cylinder heads - Page 2 Empty design
Post  Gary Blair December 20th 2013, 4:23 pm
When I originally did the model 3 years ago Mike provided me with an aluminum semi finished version of the Compresco head. It was a lot easier to work with than iron that's for sure. I've had my fair share of grinding 460 iron LOL.
The EX514 and BT Iron CJ are cast off aluminum tooling which allows for thicker cross sections like the deck and other places. That's why they end up being so heavy in iron.
When I raised the valve cover rail 1.25" and desiged 4 individual ports it got heavier for sure LOL. I wanted to be able to use an A-460 intake on the raised port.
The concept I came up with was a sort of plug and play port selection. So when you select a low port the roof will be pretty thick. Now you could also do a raised CJ port as well. I tried to build as much flexability as possible into the design. Sometimes when you ask something to do too many things it doesn't want to. I had a girlfriend like that once. I think this head will do pretty well though.
This head will also have an indistrial application for alternative fuels.
I really wanted to get out to the PRI but I've been a little under the weather.
Gary Blair
Gary Blair
Post  557ranger December 21st 2013, 8:48 pm
Are these available to buy now? Or when are expected to be available?
557ranger
557ranger
Post  schmitty December 21st 2013, 9:19 pm
Late Jan/early Feb.
Post  AL Q December 31st 2013, 10:50 pm
schmitty wrote:Saw the new cast iron Eliminator heads at PRI.  I will post a few pics when I get home.  Mike Bowery said that he can make this head with either the "A" style, or CJ style intake port, and either the chevy or Ford style exhaust.  He had a machined head there with the A port and chevy exhaust, that was pretty impressive.  These heads all have stock valve geometry, so if you have a good set of pistons already, you will be able to upgrade without having to change them.  He said that aluminum versions will be out in the near future also.  Another product that is now available from them is a block that can be decked down as low as 9.5".
Would be cool to see a block with gm bell pattern and starter mounting
AL Q
AL Q
Post  steven gregoire January 2nd 2014, 5:45 pm
^ that would make it alot easier to deal with transmissions at the track.
steven gregoire
steven gregoire
Post  Captainp4 January 2nd 2014, 9:41 pm
Any idea what the cj intake/ bbf exhaust version will flow out of the box?
Captainp4
Post  BOSS 429 January 2nd 2014, 11:20 pm
lghting94 wrote:Best I remember the ex-514's were around 100 pounds each so if these are that or less that's good.  Having any aftermarket iron head will help a lot of guys trying to compete in the all iron classes.
yup 110 each after c n c porting
Post  BOSS 429 January 2nd 2014, 11:22 pm
the elm blocks have a starter pad on the drivers side already for a gm type bolt on starter
Post  557ranger March 16th 2014, 10:53 pm
any news on when they will be available?
557ranger
557ranger
Post  bbf-falcon September 13th 2014, 8:38 am
update
Post  EverySparePenny August 21st 2018, 4:40 pm
Now that these have been out awhile, anybody do much work with them? Good potential?
EverySparePenny
Post  Lem Evans August 21st 2018, 6:59 pm
EverySparePenny wrote:Now that these have been out awhile, anybody do much work with them?  Good potential?
Who has ran these heads?
Post  EverySparePenny August 21st 2018, 7:09 pm
Nobody that I personally know of, that's why I ask. They are very intriguing to me.
Sent from Topic'it App
EverySparePenny
Post  68formalGT August 22nd 2018, 11:15 am
I know a mud racer that bought a set but I don't know if he has them on an engine yet.
