TFS A-460 changes?
+6
tfsbbf466
norm
Wheelie58
JBR-3
J.Toney
10 posters
Page 2 of 2 Previous  1, 2
TFS A-460 changes? - Page 2 Empty Re: TFS A-460 changes?
Post  powerstrokeace December 29th 2013, 11:43 am
c.evans wrote:
powerstrokeace wrote:So what does on have to do to run the BBF1 heads for correctin the steam holes?
Ace
What I have done for years is use a small carbide burr and convert the round shape of the steam hole to a tear drop shape. On the heads you need to elongate the hole upward towards the manifold.  Then on the A-460 blocks you need to elongate the holes downward towards the lower head bolt. Then you need to use a Cometic head gasket from Lem with his own part numbers.
It was Fel-Pro that screwed everything up in the first place about 15+ years ago.  Then any manufacturer who copied the Fel-Pro gasket blue prints continued to make the same error.
Charlie
So what about a stock block?
Ace
powerstrokeace
powerstrokeace
Post  Lem Evans December 29th 2013, 12:05 pm
A stock block has no steam holes.
Post  powerstrokeace January 1st 2014, 12:49 pm
What year did they go to the BBF2? I have 2 sets of BBF1's one set was purchased in early to mid 2008. The other set I have no idea as the so called serial numbers on the ends are different. A-1069-2 and A-1058-2 on the set purchased in 2008 and A-444A and A437A on the unknown heads. Both are 2.350/ 1.88
Acr
powerstrokeace
powerstrokeace
