Question about setting valves
Ok, I sat down yesterday to set the valves on my 429 . The way I did it was to remove the distributor cap and turn the crank until I reached a cylinder that was suppose to hit TDC. I then adjusted those two valves. Then I went around the cap until I got them all done. But, I ran into a couple that when I adjusted to zero lash and tried to go 3/4 turn more, it seemed like the valve got pretty tight so I stopped . Is this a common thing? I adjusted each cylinder until the push rod wouldn't turn by twisting , then waited a minute , then tightened 3/4 turn. Did I do this the correct way? Thanks
Bigred69- Posts : 70
Re: Question about setting valves
http://www.460ford.com/forum/showthread.php?t=97066
bbf-falcon wrote:http://www.460ford.com/forum/showthread.php?t=97066
Ok, I have read that thread and still have questions. I have been told that I have thunder jet rail type rocker assemblies. And what I was told is that once I bring to TDC for that cylinder, to tighten the nut to a certain torque value, and that's it. For some reason I thought these were adjustable rockers. So 25 ft lbs with the lifters on the base circle of the cam lobe for that cylinder and that's it?
Bigred69 wrote:bbf-falcon wrote:http://www.460ford.com/forum/showthread.php?t=97066
thunderjet (cast iron ) rockers in stock form are positive stop,no ajustment
check this by looking at stud, neck down is pos. stop
BOSS 429- Posts : 2372
466cj- Posts : 391
» Procedure for setting valves ....
» setting valves one sbf with old 351w heads
» the dove c heads i bought , i measured the intake valves they were 2.250 assuming these are not stock valves ?
» setting roller rockers
» inital timing setting
