Comp cams roller
Comp cams roller
Guys i have a comp cams roller for sale its as follows. .839/.780 lift .277/.286 duration @ .050 has a 111.0 lobe separation and a 111.0 intake center line. This has 19 passes before a lifter failed and was removed. We ordered the same cam on a 24 hour rush to make a race the following weekend since this cam was thought to have lobe damage. The cam was sent back to comp cam where all the did was polish it out and return it. So there no need for 2 of these and my current build has a different requirements.
this was for a 555 ci motor with a 4.560 bore 4.250 stroke using Ford "A"460 heads
$300 shipped OBO NEW LOWER PRICE $250 + SHIPPING 4/12/2014
Ace
Ace
powerstrokeace- Posts : 1496
Re: Comp cams roller
Have you dynoed your motor with this cam?? What is the rpm range?
motivated34- Posts : 13
SORRY NO DYNO RESULTS JUST SEAT OF THE PANTS DRIVING. CONVERTER STALL TO 5800 AND THIS THING IS STILL PULLING AT 7000 RPM'S BUT WE NORMALLY SHIFT ON TIME FOR SUPER COMP RACING.
ACE
ACE
Ok i just purchased a 557 A headed motor in pieces with a nitrous cam, looking for a NA cam. But I need to make over 900 hp, do you think your cam would make that happen, this 557 I bought did make 908 with this cam I have now. But I want more HP
motivated34 wrote:Ok i just purchased a 557 A headed motor in pieces with a nitrous cam, looking for a NA cam. But I need to make over 900 hp, do you think your cam would make that happen, this 557 I bought did make 908 with this cam I have now. But I want more HP
IT WOULD BE PRETTY CLOSE / BUT DYNO RESULTS AND TUNNING PLAY FACTOR. i WOULD BET MY MOTORS ARE RIGHT AT 900HP
ACE
NEW PRICE $275 + shipping
Ace
Ace
Need this gone
Ace
Ace
NEW LOWER PRICE $250 + shipping
Ace
Ace
$250 + SHIPPING NEEDS TO GO!!!!!!!!!!
ACE
ACE
Last edited by powerstrokeace on October 11th 2014, 8:40 pm; edited 1 time in total
Is this the new cam?
What compression did the 555 have?
torino501- Posts : 417
This is the cam that was polished out. No spec's were changed at all and for what ever reason comp retagged it as a regrind number. No idea why that was done!torino501 wrote:Is this the new cam?
The compression is 13:5.1
Hope this helps
Ace
» Comp cams roller cam
» Comp Cams roller rockers 1:80
» Comp Cams Roller Lifters
» Comp cams solid roller cam
» Big comp cams solid roller
