2014 garage clean out
new three speed floor shifter with fiber glass floor piece for 66 bronco 100
Wilson pro flow nitrous kit part number 390210 comes with new bottle brackets, new bottle new bottle valve , line, carb switch and bracket and wiring kit. Cost more than 1000 bucks new 700 bucks
one parts store tote full of different size and length braided hose 100 bucks.
T5 hurst short throw shifter 70 bucks
Fresh.030 over 66 289 block needs cam bearings and freeze plugs installed have rods 100 bucks
Long tube headers for 302 in 79 to 93 mustang 75 bucks
Tote full of T5 mustang transmission parts 125 bucks
.030 DOVE -A block has a couple sleeves in it 250 bucks
Set of AFR 205 heads ready to bolt on 1400
1.6 Harland sharp roller rockers sbf 300 bucks new in the box
393 kit used eagle 3.85 crank prob I beam rods ( not the cheap I beam rods ) prob small dish pistons new harmonic balancer all of it is Balanced 1000.
Comp cams solid roller cam , lifters, and pushrods 300 bucks
9.5 Vic. Jr. Intake 150
BBK long tube headers 13/4 primary tube with 3" exhaust and bullet mufflers for fox platform mustang 300 bucks
AFR valve covers black wrinkle finish. 80 bucks
Or buy it all for 3000.
I will be adding more parts as time permits.
All parts buyer is responsible for shipping cost and pick up.
Pic are available threw txt or email on all of the above parts.
Thanks Whitey
Thanks Whitey
whitefield- Posts : 2244
Re: 2014 garage clean out
Where are you at again?
jbozzelle- Posts : 3705
jbozzelle wrote:Where are you at again?
John I believe he is in TEN I SEEE
69F100 wrote:jbozzelle wrote:Where are you at again?
That B most correct !
Bump Bump Bump surely some one could use some of these parts !
new2460 wrote:How much for the c4? Any trades?
1400 has zero miles on it. Make me a reasonable offer. Thanks Michael Whitefield
more info on 393, cam included? year of block? what kind of pistons? oil pan included?
motivated34- Posts : 13
motivated34 wrote:more info on 393, cam included? year of block? what kind of pistons? oil pan included?
Stock double sump oil pan .
Pistons are Mahle forged pistons and rings
Nib hydraulic roller cam custom grind
Or I have two solid roller cams these are custom grinds as well for 393w.
I can get the cam specs if you need. Thanks Michael
What tha heck let's bump this one up too !
» Garage Clean out
» Garage Clean Out
» Very low milage .030 KB138 Pistons, 8 car rods and 2 crankshafts $200
» Garage Clean Out- Everything Sold
» GARAGE CLEAN UP...PARTS FOR SALE
» Garage Clean Out
