max rpm on stock D1VE engine????
racinghabbit
max rpm on stock D1VE engine???? Empty max rpm on stock D1VE engine????
Post  racinghabbit January 12th 2014, 10:01 pm
What is the max rpm you would run a stock lowerend of a 460, D1VE engine???? mud racing is what i'm doing wide open for 10sec or less
racinghabbit
racinghabbit
max rpm on stock D1VE engine???? Empty Re: max rpm on stock D1VE engine????
Post  bbf-falcon January 12th 2014, 10:05 pm
It would depend upon how many passes you would need it to last.  Smile
Post  racinghabbit January 12th 2014, 10:07 pm
40 passes, and its an old used lower end
racinghabbit
racinghabbit
Post  dfree383 January 12th 2014, 10:22 pm
5500-6000 if it's in good working order
Post  racinghabbit January 12th 2014, 10:37 pm
i've had a couple 460's.. newer ones.. 87-91 motors. that the pistons break apart...
i'm going to set the rev limiter at 4700.....
i'm thinking the older stuff is better.......
racinghabbit
racinghabbit
Post  supervel45 January 12th 2014, 11:05 pm
racinghabbit wrote:i've had a couple 460's.. newer ones.. 87-91 motors. that the pistons break apart...
Don't know about the newer pistons. My 429 has D1 short bock with stock pistons and a mildish grind hyd. cam. The bottom end and pistons worked fine in 1/8 drag racing, with 150 shot of N20 for quite a while at 5,500 rpm. It would most likely still be going, if I had not dropped a valve. At least if the bottom end goes you are out of less money. I was impressed with the stock parts.
Post  racinghabbit January 12th 2014, 11:18 pm
Thanks for the info... the more the better...
racinghabbit
racinghabbit
Post  69F100 January 13th 2014, 12:42 am
my d9 460 stock bottom end I turned it 6500 max with ported dove heads and solid flat tappet cam
Post  BOSS 429 January 13th 2014, 12:52 am
69F100 wrote:my d9 460 stock bottom end I turned it 6500 max with ported dove heads and solid flat tappet cam
6500 is more like it. We run them a lot higher
4700 Sad
Post  racinghabbit January 13th 2014, 9:18 am
what pistons are you running?? I've had 3 motors where the wrist pin is connected to the rod and rod is fine and piston is blown apart.. (i had O.E. stock pistons)
racinghabbit
racinghabbit
Post  BOSS 429 January 13th 2014, 10:37 am
[quote="racinghabbit"]what pistons are you running?? I've had 3 motors where the wrist pin is connected to the rod and rod is fine and piston is blown apart.. (i had O.E. stock pistons)[/quote
STOCK CAST, good tune is the key
Post  dfree383 January 13th 2014, 11:00 am
BOSS 429 wrote:
racinghabbit wrote:what pistons are you running?? I've had 3 motors where the wrist pin is connected to the rod and rod is fine and piston is blown apart.. (i had O.E. stock pistons)[/quote
and having something that's not wore out in the wrong places.
Post  56Tbird January 13th 2014, 1:33 pm
6200 is where I found the limit on stock rods  Shocked affraid
56Tbird
56Tbird
Post  69F100 January 13th 2014, 2:01 pm
I ran the stock 89 model fuel injection pistons until swapping to the cheap speed pro flat top to bump the c/r up some the engine is still running or was when I pulled it and built my 552 the 460 is sitting on a engine stand and ready to be put in something one day
Post  466cj January 13th 2014, 2:27 pm
Know of a 429 run in a 58 Edsel in the late 1960's. Cam, upgraded valvetrain, homemade TR, stock bottom end saw 8,200 rpm more than once... cast pistons tend to break off the skirts after awhile...
466cj
