Oem 3rd member v/s fab 9 housing
bigblok2000ranger
tconnection
Oem 3rd member and fab9,
Will an oem 3rd member work or fit in a fab9 housing?
Thanks Earl
Thanks Earl
tconnection- Posts : 866
Re: Oem 3rd member v/s fab 9 housing
Bout how much hp can it handle?
the oem 3rd member or the fab 9 housing?
not near enough to need a fab9.tconnection wrote:Bout how much hp can it handle?
application?
whatbumper- Posts : 3024
Strange 40 spline gun drill axles and spool. Im figuring the engine is high 900 to a 1000hp.
40 spline wont fit oem case.tconnection wrote:Strange 40 spline gun drill axles and spool. Im figuring the engine is high 900 to a 1000hp.
Im really green to 9'' rears. Oem case, r u referring the the 3rd member? I thought the axles fit in just the spool.
Lee meant the 40 spline stuff needs a 3.250" center section/case factory is 3.062". Are you asking how much the factory housing will handle or the factory center section/case?
Well if 40 spline stuff want fit oem case I wouldn't be using an oem case.
THANKS
THANKS
get a good case and dont look back! it does cost more to do it twice.tconnection wrote:Well if 40 spline stuff want fit oem case I wouldn't be using an oem case.
THANKS
Ok thanks
http://www.summitracing.com/parts/yga-32099/overview/
or
http://www.summitracing.com/parts/yga-32100/overview/
or
http://www.quickperformance.com/Ford-9-Inch-Moser-Nodular-Iron-HRW-Pro-N-complete-Center-Section_p_38.html
All in all a pretty good deal here.
whatbumper wrote:http://www.quickperformance.com/Ford-9-Inch-Moser-Nodular-Iron-HRW-Pro-N-complete-Center-Section_p_38.html
Just a little note; if you buy the Quickperformance center section or one of their spools make sure to let your axle supplier know this. My buddy just had to order one axle from Strange because the customer ordered one of these and one side needed to be shorter or longer by 1". I can ask to confirm which tomorrow.
Any pointers on building a pretty tough 40 spline third member for under 900.00 bucks? Which case, would the 28 spline pinion do good? this is for sure all out drag. Atleast 900hp.
Leaf spring version of the Fab9 will not last without modification unless they have changed the perches. Spring perches of my Fab 9 were not boxed and soft material. They rolled around the tube at first launch with traction letting the pinion rise and break the u-joint.
Calypso- Posts : 71
I use him for all my parts when we built my rearend never had a problem he knows the ford 9'' even bought my Moser axles from him I called him on Saturday when I change my u joint to the 1350 told him what I was doing I had it in on Tuesday. If you call him and he don't answer leave a message he will call you back.
I don't think you can blame Brydon for someone else not measuring axles for their application.bigblok2000ranger wrote:whatbumper wrote:http://www.quickperformance.com/Ford-9-Inch-Moser-Nodular-Iron-HRW-Pro-N-complete-Center-Section_p_38.html
I've gotten excellent service and support from them on several axles I've done.
Unless you find someone willing to sell a used unit, you aren't going to do it much cheaper than that nodular deal.
schmitty- Posts : 4538
schmitty wrote:I don't think you can blame Brydon for someone else not measuring axles for their application.bigblok2000ranger wrote:whatbumper wrote:http://www.quickperformance.com/Ford-9-Inch-Moser-Nodular-Iron-HRW-Pro-N-complete-Center-Section_p_38.html
Just for reference the customer ordered an F body 9" with strange axles for a strange spool from Trick Chassis but bought the center section from quick preformance. Alex had sold over 100 of the rear ends and axle packages and zero issues until this customer bought that center section. Strange now has the correct dimensions for the quick performance spools. All my point was that to make sure your axle company know what brand of spool you are using.
Nothing wrong with that advice. Just remember where you posted it. I ran a N case into the 7s with 35 splines at 3200+ with no issues.bigblok2000ranger wrote:schmitty wrote:I don't think you can blame Brydon for someone else not measuring axles for their application.bigblok2000ranger wrote:whatbumper wrote:http://www.quickperformance.com/Ford-9-Inch-Moser-Nodular-Iron-HRW-Pro-N-complete-Center-Section_p_38.html
» need a bell housing for C4
» C4 bell for the Big block
» bell housing
» Which bell housing?
» C4 Bell housing
» bell housing
» C4 Bell housing
