how big can you go
how big can you go
how big can you make a stock 460 block (safe)
fastgerber- Posts : 1
Re: how big can you go
Without a sonic check its hard to say, 4.42 is safe most cases.
Depends on the use as well.
Yep , unless you are going to sonic check the block the .030"/.040"/.060" overbores are the safest places to be .
Occasionaly their are some that will go 4.500........ But that's not normaly the case.
VERY abbynormaldfree383 wrote:Occasionaly their are some that will go 4.500........ But that's not normaly the case.
Ah yes Dr. Frank-n-schteenLem Evans wrote:VERY abbynormaldfree383 wrote:Occasionaly their are some that will go 4.500........ But that's not normaly the case.
odfree383 wrote:Occasionaly their are some that will go 4.500........ But that's not normaly the case.
I have one of them there blocks, but I'm not about to bore it that far unless totally necessary.
Best thing is to only bore the block enough to clean it up, because the more metal surrounding the piston the better.
schmitty- Posts : 4538
