x
x Empty x
Post  138n January 18th 2014, 12:27 pm
x
138n
x Empty Re: x
Post  bbf-falcon January 18th 2014, 12:32 pm
I had my Machinist take .050 from the side of caps. Or you can buy a pan that's for block.
x Empty Re: x
Post  Wheelie58 January 18th 2014, 1:29 pm
I have experienced an older block and pan combo where the caps had to be machined and the pan also modified. If you are having a custom pan made, the fabricator can add clearance during the build.
Keith
Wheelie58
Wheelie58
x Empty Re: x
Post  Lem Evans January 18th 2014, 1:51 pm
The A460 blocks from the past several years have different machining at the cap ends than the older blocks. They require little to no mods. depending on how the pan is built
If you 'love' on the caps be sure to only work the portion that is above the pan rail.
x Empty Re: x
Post  Wheelie58 January 18th 2014, 2:35 pm
Lem Evans wrote:The A460 blocks from the past several years have different machining at the cap ends than the older blocks. They require little to no mods. depending on how the pan is built
Yeah Lem...
That block was so old, it should be in a museum, and still lives at 4.625". Shows how tough those things are.
Good tip on not milling the outer registers off...
Keith
Wheelie58
Wheelie58
x Empty Re: x
Post  cool40 January 18th 2014, 8:37 pm
Today i ran in to this. I fit the pan on the car, eliminator block, then decided to use the block on the engine stand for setting up the pump mount.its a FMS and to my surprise it hit the caps.lol
x Empty Re: x
