Crank end play
BigRigTech
powerstrokeace
Crank end play Empty Crank end play
Post  powerstrokeace January 19th 2014, 2:58 am
Is .003 to tight for a drag only motor.
Ace
powerstrokeace
powerstrokeace
Crank end play Empty Re: Crank end play
Post  cool40 January 19th 2014, 10:28 am
Yes.
Post  richter69 January 19th 2014, 11:26 am
.004-.008. lightly sand the sidemof the thrust and open it up.
Post  BigRigTech January 19th 2014, 11:26 am
.004 to .008 is desired.
BigRigTech
BigRigTech
Post  powerstrokeace January 19th 2014, 11:33 am
So sanding the thrust side of the bearings is acceptable ? And what do you recommend I use for the operation?
Ace
powerstrokeace
powerstrokeace
Post  bosshoss January 19th 2014, 11:44 am
personally I would sand the non thrust side only.
A nice piece of 1/4" plate glass works ok for a flat surface if you dont have acces to like a granite test block or some such.
Lay a piece of fine sand paper or emery cloth on the flat surface face up.
Place the bearing shell face down on the paper and gently move it in a figure 8 pattern while applying gentle pressure.
a Shot of WD 40 may help keep the paper from plugging up during this process.
Check the clearance often.
Kinda like filing rings... rub a bit, test, rub some more test again.
 Cool
dkp
bosshoss
bosshoss
Post  richter69 January 19th 2014, 11:57 am
Ive had to do this on the last couple builds ^^^^^^ works fine
Post  Lem Evans January 19th 2014, 12:25 pm
I prefer not to be less than .005". It helps to figure out if the block or cap 1/2 is the bigger issue.
Post  powerstrokeace January 19th 2014, 12:53 pm
Lem Evans wrote:I prefer not to be less than .005". It helps to figure out if the block or cap 1/2 is the bigger issue.
It an Ohio crank and I'm betting its tight. I have not contacted my crank guy as he may have rushed through this and missed it. He was leaving for Xmas vacation. I have not even paid him yet. Also Lem it's a stock block using the Kingb5242hp bearing I got from you a while back
Ace
powerstrokeace
powerstrokeace
Post  Lem Evans January 19th 2014, 1:16 pm
The brand of bearing does not seem to matter. Most of the Scat cranks seem to be about .003" too.
Post  powerstrokeace January 19th 2014, 1:19 pm
Lem Evans wrote:The brand of bearing does not seem to matter. Most of the Scat cranks seem to be about .003" too.
So I'll massages the thrust side of the Bearings to get .005.an I'm getting old lifting this thing in and out. Next crank will be a super lite deal
Ace
powerstrokeace
powerstrokeace
Post  cool40 January 19th 2014, 1:44 pm
You did "seat"the cap didn't you? If not you may not need to sand the bearing.
Post  Wheelie58 January 19th 2014, 2:31 pm
Good tips all around. Boss posted a good procedure. I use wet/dry auto body paper with solvent or WD for lube.
600 grit helps make for a tedious..controlled removal.
Cool's tip about seating the bearing is another good point. That can pick up at least a thou in most cases.
That is...with the bearings installed and the cap tightened...then backed off to snug...
Use a big dead blow mallet and give the center of the rear crank flange a good whack or 2. You can also carefully use a chunk of brass to protect the crank and a regular hammer.
Just lines up the shells...
I like .007" end play.
.005" will work.
Keith
Wheelie58
Wheelie58
Post  powerstrokeace January 19th 2014, 2:46 pm
Wheelie58 wrote:Good tips all around. Boss posted a good procedure. I use wet/dry auto body paper with solvent or WD for lube.
.005" will work.
Keith
OK. Pretty much did it all. and we ended up at .006. so its all good. i will now check deck height using 4 piston in each corner with out the rings measuring at the center or just above the pin. and then file fit the rings per hole and mount them on the pistons. not sure ho much i'll get done here as there some kind of football game on today day thats getting a lot attention . Rolling Eyes
Ace
powerstrokeace
powerstrokeace
Post  Lem Evans January 19th 2014, 3:19 pm
Seating the cap is a good idea but, with the doweled caps like an A460 block, there is little to get.....unlike the typical production blocks.
Post  Lem Evans January 19th 2014, 3:24 pm
"I like .007" end play."
That's a good place to be with the really big engines.
Post  TravisRice January 19th 2014, 3:43 pm
I've owned 2 Scat Billet cranks and both were tight on the thrust by about .003-.004. The block was a DIVE with the splayed Engine Systems 4 bolt main caps on the center 3. Only throwing that out there for the fact that the billet seemed no better than the cast in that respect. Personally I would rather have it on the tight side so you can customize the tolerance to your needs............ hard to add to it when you need it ( if it was on the large side to begin with )
