best oil temp for drag racing
D. Sea
Larry Williams
nickbay
best oil temp for drag racing Empty best oil temp for drag racing
Post  nickbay November 4th 2009, 3:24 pm
Now that I've got an oil temp gauge I've noticed this. My engine runs around 190 water temp, the oil takes a long time to warm up.
It seems like it takes forever to get to 140, then if I drive it enough it will eventually get to around 180.
I have been running my car at the track by warming it up to about 180 degrees water temp, but now I know my oil would be cold.
Do I run the car until the oil is warmer or just go by the water temp?
I currently run Mobil 1 15-50 synthetic which has 1200 parts zddp.
I have around 62 psi oil pressure, which goes down to around 50 psi at idle when warmed up.
I run a Ford high volume pump and a 7 qt pan.
nickbay
nickbay
best oil temp for drag racing Empty Re: best oil temp for drag racing
Post  Larry Williams November 4th 2009, 3:53 pm
oil pan heater oil temp is important
Larry Williams
Larry Williams
Post  D. Sea November 4th 2009, 4:01 pm
Good question... I'd also like to know, subscribing...
I always drive through the pits a few laps to warm up the engine and drivetrain. Then when we are called to the lanes I'll warm my engine up in the lanes up to 180+ before shutting it down. Now this last race it was COLD!!! and It took FOREVER to get heat into the engine...
I try to run the car at 190-200F
D. Sea
D. Sea
Post  richter69 November 4th 2009, 4:03 pm
I have one of the stick on heating pads on my oilpan, its pluuged in all the time.............only when I leave the pit is it not in use. Now this is an alky deal, and prolly one reason i can go so long on the oil change intervals, hell I change it once mid season and thats it.
I have a heater in the radiator, may add some to the block this winter though, also one on the diff as it takes forever to warm up.
best oil temp for drag racing Empty I shoot for 180 Oil Temp.
Post  512Fairlane November 6th 2009, 11:19 pm
I usually try to get my oil temp up to 180 degrees before making a pass. My water temperature takes longer to come up though. I'll usually hit 180 oil temp and my water may only be at around 160. I run Mobil 1 15W-50 Synthetic. At the winter tech seminar Adney Brown brought a sheet that gave recomended oil temperatures for different types of oil. I think thats where I came up with the 180 degree number.
512Fairlane
512Fairlane
Post  bruno November 7th 2009, 12:09 am
i know my fastest passes are when the water temp is 180+ ....... off the trailer the first pass is usually 140-150
http://WWW.CKRME.COM
Post  Larry T November 7th 2009, 12:30 am
when i was on the dyno last year the oil temp didnt come up that fast.mike philips asked me if i had a oil restrictor in the block and i said no,he said that is the reason the oil temp dosent rise that fast.he said i would have to warm up the motor alittle longer but wasnt a problem i dont recall what he said the oil temp should be though.
water temp on the dyno started at 165 and ended at 175.oil temp started 170 and ended at 180.
Larry T
Larry T
