Profiler and C460 rocker arms
Profiler and C460 rocker arms Empty Profiler and C460 rocker arms
Post  psfracer January 29th 2014, 11:47 pm
Do they use the same rocker arms?  Here is what I have.  Exhaust looks normal, intake is offset.  Same for the C460? Seeing how the profiler 205 is kind of regarded as the C460 replacement head, I am thinking yes--but I do know the intake port is raised .200 -- does that make any difference here?
Profiler and C460 rocker arms Rockerarms1
Profiler and C460 rocker arms Profiler205intake1web
psfracer
psfracer
http://www.psfracer.com
Profiler and C460 rocker arms Empty Re: Profiler and C460 rocker arms
Post  Frank Merkl January 30th 2014, 11:46 pm
does the C460 rockers and stands bolt on?
frank
Post  psfracer January 30th 2014, 11:51 pm
I am not sure as i only have profilers, i dont have a pair of c heads. They bolt up to the profilers just fine.
psfracer
psfracer
Post  DanH January 31st 2014, 12:34 am
whats the offset on the intake rocker? Post the letters stamped on the rocker
DanH
Post  Frank Merkl January 31st 2014, 1:17 am
well I have 5 sets of C460's , with one set of heads with the jessels and 4 sets of heads and and 6 sets of the ford Crane rockers and the ford Crane are way stronger with bigger shafts
frank
Post  Frank Merkl January 31st 2014, 1:20 am
letter stampimg on the jessels is EWHB85
frank
Post  Frank Merkl January 31st 2014, 1:21 am
exhaust EAAS80
FRANK
Post  psfracer January 31st 2014, 2:19 am
Ok here is what I have:
The exhaust is FAAS80
The intake is EQGR80
Does the 80 mean they are 1.80 ratio?
psfracer
psfracer
Post  Frank Merkl January 31st 2014, 2:41 am
80 = 1.80 ratio
pics of mine
RL=https://s58.photobucket.com/user/fmerkl/media/C460rockers001_zpsac74965c.jpg.html]Profiler and C460 rocker arms C460rockers001_<a href=Profiler and C460 rocker arms C460rockers002_zps75b67381" />[/URL]
on the left is my jeesels , on the right is the ford crane deal
Post  psfracer January 31st 2014, 12:59 pm
Ok I found the rocker arm chart from Jesel in their online catalog. The letter code breakdown looks like this:
Profiler and C460 rocker arms JeselRockerArmChart
psfracer
psfracer
Post  Frank Merkl January 31st 2014, 5:06 pm
I'm going to save that chart ! good info!
Post  psfracer January 31st 2014, 7:29 pm
some of the above measurements defined:
Profiler and C460 rocker arms Jeselmeasurementsdefined
psfracer
psfracer
Post  TravisRice February 2nd 2014, 9:18 pm
Frank Merkl wrote:well I have 5 sets of C460's , with one set of heads with the jessels and 4 sets of heads and and 6 sets of the ford Crane rockers and the ford Crane are way stronger with bigger shafts
frank
Frank,
Have you broken any of the Jesel stuff? Just curious as I have a Jesel setup also but only run a tad over 800 lift with a comp 948 triple spring and rpm the thing 7200.
Travis
Post  Frank Merkl February 2nd 2014, 10:24 pm
to be honest I haven't ran the Jessel rockers yet as they can with my 632 that I Haven' ran as of yet
frank
Post  TravisRice February 2nd 2014, 10:39 pm
The W+W Rockers that were on the other engine are the only thing I have to compare them with. Yhe shaft is definatley smaller on the Jesel, and my stands are 2 piece on the Jesel also where as the W+W were one piece, If I remember correctly the roller tip was also smaller in diameter by a smidge on the Jesel compared to the W+W. I had 200 passes on the Jesels and they were trouble free before sidelining the engine for a new project.
Post  psfracer February 2nd 2014, 11:11 pm
Interesting. Mine have 1 piece stands and they are Jesels.
psfracer
psfracer
Post  TravisRice February 3rd 2014, 2:33 pm
psfracer wrote:Interesting.  Mine have 1 piece stands and they are Jesels.
If it makes any difference I bought mine new in 2003 or 2004. Maybe something has changed in the last 10 years.
Post  psfracer February 3rd 2014, 3:31 pm
I would imagine so  Very Happy
psfracer
psfracer
Post  TravisRice February 4th 2014, 6:34 pm
I'll get some pics of them also and post them too if you would like. Might be interesting to somebody else too.
Travis
