solid roller cam in stock block
+6
69bluehotrod
4thHorseman
70429scj
10 posters
solid roller cam in stock block Empty solid roller cam in stock block
Post  70429scj January 30th 2014, 12:00 am
What mods need to be done to a dove-a block to run a solid roller cam. Motor is a pump gas bracket deal want to make 750 hp.
Thanks,
Steve
70429scj
70429scj
solid roller cam in stock block Empty Re: solid roller cam in stock block
Post  cool40 January 30th 2014, 12:02 am
none.  Very Happy
Post  res0rli9 January 30th 2014, 12:19 am
Only mods I know of is, you need to install the cam bearings first.  Smile
Post  4thHorseman January 30th 2014, 10:58 am
The wallet mod. Freaking lifters are nearly as expensive as the bump stick.
4thHorseman
4thHorseman
solid roller cam in stock block Empty ok
Post  70429scj January 30th 2014, 11:31 am
I thought the oil galleys had to be restricted see what I know NOTHING!!!
Steve
70429scj
70429scj
Post  69bluehotrod January 30th 2014, 12:16 pm
If you have not installed cam bearings yet , get with Lem & get a set of "wide " cam bearings.
(IIRC, Lem told me they are the #1 Cleavland style bearing, but talke to Lem & make sure on that)
69bluehotrod
69bluehotrod
http://rainbowvacuumsalesservice.com/
Post  rmcomprandy January 30th 2014, 5:39 pm
70429scj wrote:I thought the oil galleys had to be restricted see what I know NOTHING!!!
Steve
It is BEST to drill the right, (passenger), side main oil gallery to 5/8" and install lifter bushings on that side but, it is really only necessary in high RPM cases.
Post  norm January 30th 2014, 7:07 pm
Bronze thrust plate, but I ran a roller with the stock cast one for a long time before I found out that was "bad". Will have to run a bronze distributor gear on a billet steel cam.
norm
norm
Post  powerstrokeace January 30th 2014, 7:31 pm
Call Lem and get a set of the extra wide bearing from him and that's it
You might get a bronze cam retainer while your at it too
Ace
powerstrokeace
powerstrokeace
Post  J.Toney January 30th 2014, 11:03 pm
Depending on where you are, maybe Randy is a good choice for supplier also? I've gotten a few sets from him.
J.Toney
J.Toney
Post  bbf-falcon February 1st 2014, 8:57 am
Wide bearings are nice,but not a necessity for a pump gas deal imo. Very Happy
Post  69bluehotrod February 1st 2014, 2:26 pm
bbf-falcon wrote:Wide bearings are nice,but not a necessity  for a pump gas deal imo. Very Happy
With the nominal cost diff. & better support why on earth wouldn't you go with the wider ones??? fuel has really nothing to do with it...just sayin.
69bluehotrod
69bluehotrod
