Wiseco 4.560 A Head Pistons
Wiseco 4.560 A Head Pistons Empty Wiseco 4.560 A Head Pistons
Post  774 Super Street February 5th 2014, 12:09 pm
I have a brand new set of Wiseco 4.560 bore pistons for A Heads. I bought these for my 588 c.i. build and they have been mocked up in an engine. The compression was going to be 12.5 to 1 with 87cc Trick Flow heads so I bought a different set to get more compression. They go with a 6.700 rod and 4.500 in crank. The Wiseco part# is AW-04244. They come with pins, locks and a new set of total seal rings. $500 plus shipping.
Ryan 602-330-2709
774 Super Street
774 Super Street
Wiseco 4.560 A Head Pistons Empty Re: Wiseco 4.560 A Head Pistons
Post  powerstrokeace February 5th 2014, 1:06 pm
Killer deal but why such a small dome if your building a custom piston to start with. I figure its 3cc's
Ace
powerstrokeace
powerstrokeace
Post  774 Super Street February 5th 2014, 1:09 pm
I bought everything from a guy. Heads, crank, rods, pistons etc... He was going to shave the heads to bring the compression up buy I didn't wan to do that.
774 Super Street
774 Super Street
Post  774 Super Street February 18th 2014, 2:59 pm
774 Super Street
774 Super Street
Post  Mark Laczo February 18th 2014, 8:50 pm
Would those pistons work with the Ford Motorsport A460 heads ? If so they would give more comp as they are around 76cc chambers?
FWIW Mark
Mark Laczo
Mark Laczo
Post  774 Super Street February 18th 2014, 9:05 pm
You would have to call Wiseco to be sure that they would work. The compression ratio would be higher for sure with the smaller chambers.
774 Super Street
774 Super Street
Post  powerstrokeace February 18th 2014, 11:56 pm
Mark i called wiesco when this was first listed and the info they have is vage. they say its a 3cc dome for a very small chamber. they really did nt have any more info. maybe the sell has the original box and the paper work for these. this is a killer deal and will work for both Ford and TFS "a" heads. my block just happens to be needing a 4.562 bore piston so i will have to order mine. My head just so happen to be a 67cc chamber
Ace
powerstrokeace
powerstrokeace
Post  Mark Laczo February 19th 2014, 9:48 am
Ace,
If these piston mic @ 4.560" they may work for your 4.562" minimum clean up you can always bore a little more ? But if they mic @ 4.555" then they may be a little loose @ your 4.562" minimum = .007" piston-bore clearance. Depends what they mic @.
If I could make them work I would run them with a 4.3" stroke & 6.8" rod with a 76cc head it would be around 14.5 which would be decent. I haven't taken my block in yet but it may need more of a clean up than I expect in which case I couldn't use these.
Mark
Mark Laczo
Mark Laczo
Post  774 Super Street February 19th 2014, 11:55 am
I have the spec sheet from Wiseco, if you would like it leave your email address and I will send it over. Thanks
774 Super Street
774 Super Street
