Best Size BBF Stroker???
+12
powerstrokeace
LivermoreDave
Larry Williams
quick 52
514Fox87
514F-1
16 posters
Best Size BBF Stroker??? Empty Best Size BBF Stroker???
Post  514F-1 February 14th 2014, 6:25 pm
Just wondering what the experts feel is the best STOCK BLOCK BBF Stroker size? I have heard that the 4.300 stroke 514/521 combos are probably the best, just curious to see what others think Very Happy
514F-1
514F-1
Best Size BBF Stroker??? Empty Re: Best Size BBF Stroker???
Post  514Fox87 February 14th 2014, 6:44 pm
Personally if I were buying a stroker my money goes into a 4.500 arm. Just my 2 cents.
514Fox87
514Fox87
Post  dfree383 February 14th 2014, 6:47 pm
Depends on the top end and the application IMO
Post  Lem Evans February 14th 2014, 6:55 pm
Yep, application and which cyl. heads would matter.
Post  quick 52 February 14th 2014, 7:09 pm
Can more stroke hurt
quick 52
Post  Lem Evans February 14th 2014, 7:25 pm
I wouldn't use the word 'hurt' but, I can think of a few applications where I'd rather have a 533" [4.440" x 4.300"] than a 545" [4.390" x 4.500"]. It'd depend on the cyl. head/valve size and rpm range needed.
Post  rmcomprandy February 14th 2014, 8:22 pm
dfree383 wrote: Depends on the top end and the application IMO
YEP ... the top end will determine the best bottom end for the application.
Post  windsor February 14th 2014, 9:38 pm
4.68 bore but pump gas and "street friendly" cam for drag week style build????
Post  cool40 February 14th 2014, 9:58 pm
In a 2 bolt block i'd stay 4.3.IMO.....for sure if its a race motor.
Post  Larry Williams February 14th 2014, 11:11 pm
what would be considered the best size for the P51 heads as out of the box?
Larry Williams
Larry Williams
Post  c.evans February 15th 2014, 1:10 am
Larry Williams wrote:what would be considered the best size for the P51 heads  as out of the box?
I'd say something like a 533 / 545 CID for out of the box. But why? Why not just go ahead and do some porting and flow testing work, and then they can be used on anything up into the 557 / 572 CID range.
For example Bobby Shrewsberry's 557 made 942 Hp and he won the Ford Bash that year in his dragster. Randy Moore's 562 made 951 Hp and won a lot of races. Blake da Snake's 588 makes 1003 Hp and runs dang good.
Hope this helps,
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  Larry Williams February 15th 2014, 1:22 am
Hope this helps,
Charlie
i have them sitting on a 545 in the garage now. I should have taken them with me 2 years ago for you. now its a spare motor till I get to Ky with my bigger motor for repairs.
thanks for the input Charlie
Larry Williams
Larry Williams
Post  LivermoreDave February 15th 2014, 5:16 pm
A question if I may? Using factory blocks, will the longer stroke (4.5") interfere with longer cylinder barrels and with the longer stroke (4.5") is there enough cylinder (shorter cylinder barrels) to stabilize the piston at BDC?
Dave.
LivermoreDave
Post  rmcomprandy February 15th 2014, 8:25 pm
LivermoreDave wrote:A question if I may? Using factory blocks, will the longer stroke (4.5") interfere with longer cylinder barrels and with the longer stroke (4.5") is there enough cylinder (shorter cylinder barrels) to stabilize the piston at BDC?
Dave.
There are no interference problems with any factory blocks with a 4.5" stroke using a rod having a capscrew type bolt..
With a rod having a through bolt, the bolt head will slightly interfere with a later longer cylinder bore block.
Post  powerstrokeace February 15th 2014, 10:14 pm
Hope this helps,
Charlie
Charlie? What heads were on these 3 motors you speak of?
Ace
powerstrokeace
powerstrokeace
Post  dfree383 February 15th 2014, 10:29 pm
Did 870hp on this years 572 EMC engine with P-51s. Hot street setup with a hydraulic roller 11.4:1 and a 4150 carb
Post  c.evans February 15th 2014, 11:09 pm
Hope this helps,
Charlie
Ace
Fully ported and flowed P-51 heads on those three engines. It was in response to Larry's question.
Then Dave mentioned that his P-51 headed 2012 EMC contest engine was 572 CID and made 870 Hp. Again those were fully ported and flowed P-51 heads. I put the bigger 2.300" intake valve in them.
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  powerstrokeace February 16th 2014, 2:07 am
Thanks Charlie. I just did a 557 a460 head deal. Waiting on a cam right now
Ace
powerstrokeace
powerstrokeace
Post  Frank Merkl February 16th 2014, 3:11 am
From what motors I built you can not go wrong with a 4.500" stroke with a 6.800 rod even in a short wall Dive block, 4.390 bore even with ported D3 heads are torque monsters ,ie 450- 500 ft/tq @ 2200 rpm or less
Post  Rickyt630x February 16th 2014, 7:47 pm
combos i found work best were 4.44 bore 4.150 stroke, (514) 4.390 with a 4.500 stroke (545 or the 4.44 bore with 4.500 stroke (557) and a 4.42 with 4.500 (552). we've used all these combos and work great.
Rickyt630x
Post  Rickyt630x February 16th 2014, 7:49 pm
cool40 wrote:In a 2 bolt block i'd stay 4.3.IMO.....for sure if its a race motor.
why say that? its not a bowtie dont need the 4 bolts to make the power lol Very Happy
Rickyt630x
Post  cool40 February 16th 2014, 10:04 pm
for a race motor 4 bolts are better than 2. my 2 bolt d0ve block had a little cap walk but held up fine. i guess i should have said UNDER 7000 RPM.  Very Happy
Post  CDMBill February 18th 2014, 1:08 am
Even good stock block should be 4.5". Are you going to cam it enough to turn it high enough to matter? DW deal spends 99% of the time at idle to light load cruise. The length of the arm doesn't matter for that. Other than a high rpm deal the side load concerns are not a huge deal. Trying to spin it brings a bunch of concerns with valve train parts.
CDMBill
Post  supervel45 February 18th 2014, 2:01 am
        I have a Question, Cool40 has a good point. I have not seen cranksfaft balance mentioned yet. If an engine was to operate at 5-8500RPM, would it need to be balanced in this range, and not at a lower RPM level range?
Post  supervel45 February 18th 2014, 2:14 am
http://www.circletrack.com/enginetech/ctrp_0504_engine_balancing_tech_terminology/ Interesting article, especially the 427 Ford coments.
