Opinions on painting lifter valleys
+6
bosshoss
bbfstanger
fordmanmatt
10 posters
I have just learned about this and I just want to here form a few members here because I value the opinions of a lot of members here, I have heard that Glyptal and I have also head of using Por-15 so what's up with this and is it worth it ?????
Also has anybody had a block damaged from doing this?????
fordmanmatt- Posts : 33
Re: Opinions on painting lifter valleys
Some doit ,but most don't.all I will say IS,keep paint away from inside of engine.
potential paint chips scares me. i never do it.
bbfstanger- Posts : 223
Agreed. Any possible gains made by allowing oil to drain back to the pan faster are far out weighed by the damage done if one of those paint chips jams the relief valve in the oil pump
bosshoss- BBF CONTRIBUTOR
I agree, like I said on the other site, thought I would ask just did not want to have one of those moments that I should have done it LOL
There is NOTHING wrong with it if the preparation is good and it is done right; unless an alcohol based fuel is used.
I don't know of any paint or epoxy which will stand-up to a steady dose of alcohol residuals.
It used to be common practice when I bought my first 514 shortblock from Engine Systems back about 1991-92. Don't see it as often as you used to but I still have that block and it has held up well. One thing I do like is if it was prepped properly from the get go, it will actually be sealed from the oil and you can simply wash it down with hot soapy water during a freshen up or rebuild. Like Randy said about the alcohol based products, brake clean should not be used either, it will make the glyptol sticky for a period of time and it can be smeared around damaging it's integrity.
TravisRice- BBF CONTRIBUTOR
I just remembered my first running FE that I built when I was 15 years old. It was a 352 loaded with cast-away parts from older racers. I painted the valley and behind the timing cover, because I saw it in a magazine. I thought I was hot stuff, until the Permatex or Indian Head gasket sealer made the paint peel off, due to a chemical reaction. I am sure the prep was a little shaky too, with my limited experience back then.
Just had to share that blast from the past.
Keith
Keith
Gylptol originated to be used on the windings of electric "Motors"
I guess I'm the odd man out. My lifter valley is painted. No ill effects after 3 years. I didn't know that my engine builder had done it until I pulled the intake for a lifter refresh about a year ago. No flaking or lifting that I can see even with methanol for fuel. Put it back together as is and no problems to date. Just to note though, this was a brand new A460 block that hadn't been oil soaked for years before being painted.
Lem Evans wrote:600 hp or 1,200 hp.....it's just not needed.
Agree with you that its not NEEDED , but someone must have thought it did something because I have seen more than mine and David Coles done.
TravisRice wrote:Lem Evans wrote:600 hp or 1,200 hp.....it's just not needed.
Well, I did say "it's not needed" which is my opinion. If "someone" thought it did something I'm cool with that.
I'm not sure where I said not to do it but, seems that's what was inferred.
I am still of the opinion that painting the 'valley' is not a deal breaker or deal maker.
it sure looks purdy!!!
Ace
Ace
powerstrokeace- Posts : 1496
