2YABC crank
2YABC crank
how much HP can you safely but on this crank stock stroke ???
woodsideg- Posts : 3
Re: 2YABC crank
800
Re: 2YABC crank
sounds like i may be buying a crank
Re: 2YABC crank
I don't know where your wanting to go with a stock crank, but I would say it will carry more than 800 but if your wanting more than that Why would you put in a 50 $ crank in a high dollar engine.
Not being a smart azz just curious.
Re: 2YABC crank
That depends on your definition of "safely." Cast iron factory 385 Series crankshafts have supported more than 1500 hp. Even offset stroked factory cast iron crankshafts have supported well over 1000 hp.woodsideg wrote:how much HP can you safely but on this crank stock stroke ???
As is the case with most any crankshaft: as power goes up, longevity goes down.
Paul
Re: 2YABC crank
How good of a tuner are you?
Curt- Posts : 2791
» differences in 68-69 crank pulley to 70 and up crank pulley for Lincoln with crank PS
» piston to deck height
» aluminum crank pulley and a crank trigger
» Crank advice needed
