545
+9
4thHorseman
Beast
norm
quick 52
1970 ford maverick
slurm
13 posters
Sweet,Can we get more details ?slurm wrote:" />
1970 ford maverick- Posts : 180
Re: 545
dive block, 4.5 scat , 6.7 scat rods , probe dish pistons, 10.5 to 1 comp, cam spec In 258 @ .050 Ex 262 @ .050 both .650 lift cut 110 lsa. scj heads cut per Scotts web site, trick flow 4500 intake and a 1050 quick fuel. Hoping for a stumble puller going in a 63 galaxie with patc stage 3 transmission, 2500 billet converter, 9 inch with 3.70 and a ride tech four link. Any guesses on hp and torque numbers? Going on engine dyno in a couple of weeks.
slurm- Posts : 103
Re: 545
650ish. I think that converter is a bit tight for the cam.
norm- Posts : 261
Re: 545
700+ if it's built and tuned right
Re: 545
I am hoping for 650. Just bought a spear plate and a taper spacer to try on the dyno. Already thinking your right on the stall. Any good spark plug recommendations ?
slurm- Posts : 103
Re: 545
I like the AR3934 with 10.5-1 but 3923 work find and are cheaperslurm wrote:I am hoping for 650. Just bought a spear plate and a taper spacer to try on the dyno. Already thinking your right on the stall. Any good spark plug recommendations ?
quick 52- Posts : 612
Re: 545
will do thanks again lem
slurm- Posts : 103
Re 545
750 HP, 685 TQ , Tuned Up !!
Re: 545
slurm wrote:" />
That will get it done!
4thHorseman- Posts : 400
Re: 545
Where the hell do I plumb the brake booster? Or am i dreaming this thing will have vacuum.
slurm- Posts : 103
Re: 545
Stick hose in the carb!!! It'll suck the booster right off.
res0rli9- BBF CONTRIBUTOR
Re: 545
slurm wrote:Where the hell do I plumb the brake booster? Or am i dreaming this thing will have vacuum.
Brake boosters have a check valve so that you have a reserve of air that will build up during cruising. If you can use a larger carb spacer it can be drilled and tapped for your PS line. Or drill and tap the back of the carb flange.
Dave De- Posts : 797
Re: 545
Thanks for the ideas. Spacer will have to do dont have the balls to drill out the carb base.
slurm- Posts : 103
Re: 545
slurm wrote: dont have the balls to drill out the carb base.
Its a piece of cake. I drill all the way into the plenum with a 1/8" bit then the tap drill for the fitting just deep enough to tap and have sufficient thread.
norm- Posts : 261
Re: 545
Very interesting I like it. Is the cam a flat tappet or hydraulic roller?
rsears- Posts : 4
Re: 545
Guessing by the CID and your cam spec's it will have some vacuum, though probably not alot. You could drill and tap, for a fitting between the carb and the intake, on a spacer plate, and install a barb fitting. If you where joking around, never mind.
supervel45- Posts : 4499
Re: 545
no i wasn't, but already drilled the carb. (hands still shakin) thanks tho
slurm- Posts : 103
Re: 545
Your engine looks very nice, and the 63 should run really good. When you get it running, if you have a vacuum guage, I would be interested in what kind of vacuum it actually pulls at idle, and the idle RPM? With the cubic inch displacement, and the cam your are running, I would wager , it will be higher than most would expect. You can also add a vacuum canister, if you are not happy with your brake pedal sensitivity. PS: I did not see the second page, or someone posted before I did, and I missed the posts, recomending the spacer, glad you got the base drilled OK, I did one before, and it is a scarey operation like you said.
Re: 545
625 / 625 all done before 6000 rpm, still nice motor. Put manual brakes on it.
airford1- Posts : 192
