460 in a 1995 mustang
LivermoreDave
beej
just wondering if im going to have to do a lot of modifications to get the motor in my car...the guy i got it from pulled it out of a fox with no modifications to it didnt know if there was going to be a big diff between my car and a fox as far as k-member and stuff like that..any help would be appreciated thanx
beej- Posts : 3
Re: 460 in a 1995 mustang
I'm not an authority mind ya .... but, I see a lot of Ford 385's in Fox and SN95 platforms. Most I've seen look pretty neat and simple. The "newer" engine bays seem to offer adequate room for most "older engines". The "overhead cam designed" engine bays are huge compared to some.
Not much help, just an observation,
Dave.
Dave.
LivermoreDave- Posts : 972
Talked to a guy at the track yesterday with a 96 who said it was no problem... Not sure if you can buy ready made headers .He built his. They are pretty heavy.. 3300 or so lbs.
Dave C.- Posts : 1268
BBF into sn95
Sure can, I have a 95 with Skinny kid motor plates and a Racecraft K member Canton pan and Kooks headers A heads. I'm sure you could use motor mts if you wanted.
95 COBRA- Posts : 64
Started seeing a lot more of that body at the track.
Motor should fit pretty easily with minimal issues. Header and hood clearance are probably the biggest ones. However....the tunnel might need a little "massaging" or "persuasion" if you will, to fit the c6 or whatever kind of tranny your running.
Foxfire85- Posts : 35
If this is not gonna be a street driven car,its a no brainer imo to use a front plate instead of mounts.You can set the engine lower,header clearance issues are less and lots of room for accessaries.
» 1995 GT Mustang 562 cid
» 1995 MUSTANG W/ FORD 408
» . 1995 GT MUSTANG 521 CID not for sell no more
» 460 to 1995 f-250
» 1995 429 into a 1984 truck
» 460 to 1995 f-250
