front exit headers
front exit headers Empty front exit headers
Post  Rickyt630x February 24th 2014, 1:34 pm
need help on seeing how you guys are running the front exit headers on a foxbody... if you can post some pics itll be appreciated
Rickyt630x
front exit headers Empty Re: front exit headers
Post  deliveredfast February 26th 2014, 1:12 am
front exit headers Ff2_zpsce317191
front exit headers Ff3_zps32d8daf5
deliveredfast
deliveredfast
Post  yellowhorse7 February 26th 2014, 8:42 am
How long are the primaries? Let's see the collector. Dimensions?
yellowhorse7
yellowhorse7
Post  85bigblockfox February 26th 2014, 10:09 am
Can you pull the valve covers with the motor in the car?
85bigblockfox
85bigblockfox
Post  deliveredfast February 26th 2014, 10:52 am
yellowhorse7 wrote:How long are the primaries? Let's see the collector. Dimensions?
I never measured primaries.
front exit headers IMAG0616_zps5c7cb498
front exit headers IMAG0617_zps6d2f8be4
front exit headers IMAG0618_zps2a1340d7
deliveredfast
deliveredfast
Post  deliveredfast February 26th 2014, 10:56 am
85bigblockfox wrote:Can you pull the valve covers with the motor in the car?
Thats a good question Embarassed  not sure yet, have not tried. Worst case I will have to remote mount the reservoir. Shocked
deliveredfast
deliveredfast
Post  Rickyt630x February 26th 2014, 11:43 am
thanks this helps alot, car looks good too. what size are the primaries and how much modding did you do to the plate or is it just that notch on the diver side?
Rickyt630x
Post  deliveredfast February 26th 2014, 11:50 am
Rickyt630x wrote:thanks this helps alot, car looks good too. what size are the primaries and how much modding did you do to the plate or is it just that notch on the diver side?
2 1/4 primary. only had to clear driver side. Had the headers made using a different motor plate, and then I made a new 1 and cut it a lil different, thats why I had to modify it. It was no big deal.
deliveredfast
deliveredfast
Post  Larry T February 28th 2014, 12:05 am
that looks to be dyna max collector from jerry bickel that is what I am using 2-3/8x4.5
http://www.jerrybickel.com/headers-and-accessories/collectors---standard-83-812452jb.html
http://www.jerrybickel.com/headers-and-accessories/collectors---merged-80-03519jb.html
Larry T
Larry T
