Weld on adjustable Lower Control Arm Brackets
Weld on adjustable Lower Control Arm Brackets Empty Weld on adjustable Lower Control Arm Brackets
Post  bigblok2000ranger February 26th 2014, 10:01 am
I wanted to post the brackets we make for making the instant center adjustments easier.
They weld to a to the axle tube to give the lower control arm up to 11 different adjustable positions
Perfect for getting the instant center correct in the car
Weld on adjustable Lower Control Arm Brackets 2l461l
CNC aluminum spacers witk with a 3/4" rod end.
1/2 grade 8 bolts and lock nuts are included
$85+shipping
http://trickchassis.com/trickstore/index.php?main_page=product_info&cPath=5&products_id=524
608-313-9197
Trick Chassis
Last edited by bigblok2000ranger on March 5th 2014, 8:43 pm; edited 1 time in total
bigblok2000ranger
bigblok2000ranger
Weld on adjustable Lower Control Arm Brackets Empty Re: Weld on adjustable Lower Control Arm Brackets
Post  bigblok2000ranger March 4th 2014, 7:58 pm
Ready to be shipped! Smile
bigblok2000ranger
bigblok2000ranger
Post  514Fox87 March 5th 2014, 6:19 pm
What is the price before shipping?
514Fox87
514Fox87
Post  bigblok2000ranger March 5th 2014, 8:44 pm
514Fox87 wrote:What is the price before shipping?
$85 Sorry forgot to list the price.
bigblok2000ranger
bigblok2000ranger
Post  bigblockfox468 March 6th 2014, 10:26 am
Just wondering what tube diameter are they for? Or are all axle tube diameters the same?
bigblockfox468
bigblockfox468
Post  yellowhorse7 March 6th 2014, 10:46 am
bigblockfox468 wrote:Just wondering what tube diameter are they for? Or are all axle tube diameters the same?
Ive asked the same question???
3"?
3.25"
8.8?
yellowhorse7
yellowhorse7
Post  bigblok2000ranger March 6th 2014, 11:27 am
We have 3" in stock but can have 2 7/8, 3 1/4 made with a simple call to the laser shop.
bigblok2000ranger
bigblok2000ranger
Post  bigblockfox468 March 6th 2014, 1:21 pm
bigblok2000ranger wrote:We have 3" in stock but can have 2 7/8, 3 1/4 made with a simple call to the laser shop.
Would the price be the same if I don't have a 3" diameter tube? I have an 8.8 and will need to see what the tube size is. I have a few more questions so should I talk with you or call the number you supplied?
bigblockfox468
bigblockfox468
Post  bigblok2000ranger March 6th 2014, 1:46 pm
Call the number as he will be able to answer better and take care of your order. The 8.8 axle tube is 2 7/8" so you could use the brackets as is with some careful welding.
bigblok2000ranger
bigblok2000ranger
Post  514Fox87 March 6th 2014, 8:38 pm
I'll take a set how do I need to pay? Shipped to 19952
514Fox87
514Fox87
Post  bigblok2000ranger March 6th 2014, 8:45 pm
514Fox87 wrote:I'll take a set how do I need to pay?  Shipped to 19952
Call 608-313-9197 between 8am-6pm
bigblok2000ranger
bigblok2000ranger
Post  bigblok2000ranger March 7th 2014, 11:39 am
The first hole is 3" below the centerline of a 3" axle tube with two rows of holes 3/8" in height difference (including both rows). The bottom hole is 6 3/4" below axle centerline. The second row of holes is 3/4" behind the first row on center.
bigblok2000ranger
bigblok2000ranger
