Need help!
Need help!
What size, including length, are the bellhousing bolts for a 460/C6?
pigs521bbf- Posts : 173
Re: Need help!
7/16-14 x 1 1/4" long I do believe.
61coon- Posts : 1824
Re: Need help!
61coon wrote:7/16-14 x 1 1/4" long I do believe.
I know this sounds dumb but what is the 14? Is the thread fine or regular? grade 8 bolts should be all right?
Re: Need help!
pigs521bbf wrote:61coon wrote:7/16-14 x 1 1/4" long I do believe.
Stock is a grade 5 bolt and the 14 is threads per inch. Coarse bolt thread , grade 8 would work .
whitefield- Posts : 2244
Re: Need help!
^^^^ what he said. Grade 8 bolts will work great! Imperial (standard) bolts are measured by threads per inch. Metric are measured by distance between the pitch of the threads. i.e m10x1.5 means 10mm diameter and 1.5 mm between the pitch of threads.
Re: Need help!
61coon wrote:^^^^ what he said. Grade 8 bolts will work great! Imperial (standard) bolts are measured by threads per inch. Metric are measured by distance between the pitch of the threads. i.e m10x1.5 means 10mm diameter and 1.5 mm between the pitch of threads.
I believe this guy stayed at a Holiday Inn Express
