spring cups or spring isolators?
Like the title says, cups or isolators? Pros and cons?
Last edited by rcasonbbf on March 1st 2014, 9:15 pm; edited 1 time in total (Reason for editing : spelling)
rcasonbbf- Posts : 26
Re: spring cups or spring isolators?
What's an isolator?
Isolator has the raised edge on the inside.
rcasonbbf wrote:Isolator has the raised edge on the inside.
That's not an isolator, they are called locators.
They both do the same thing and are equal IMO. Only advantage I see is using the locator where you have limited dia capacity as the cups require additional space.
I.D. Locators won't require making the spring seat diameter larger however, they only work well if they are the correct ones for that application.
» needed spring seat cups
» Affect of valve spring install height on spring rating..
» ISO engine mount brackets
» Autometer 2 5/8 chrome cups ( 5 total )
