Weld seepage
Larry T
Tore
Weld seepage Empty Weld seepage
Post  Tore March 8th 2014, 10:55 pm
I had a fitting tig welded into tranny pan for a sending unit. One spot on the weld is seeping a little. I really don't care to pull the pan off as its sealed pretty good. Can I drain the fluid and put some type of sealer on the weld till I need to pull the pan. What can I use for the sealer??
Tore
Tore
Tore
Weld seepage Empty Re: Weld seepage
Post  Larry T March 8th 2014, 11:27 pm
jb weld works good for things like that but don't get the 1hr stuff I haven't had good results with it.clean up the area with sand paper leaving a rough textured area for adhesion and clean with brake or carb cleaner.
Larry T
Larry T
Post  dfree383 March 8th 2014, 11:31 pm
Try peening it.
Post  richter69 March 9th 2014, 1:06 am
Got my smashed oil pan through half a season......
Post  Tore March 9th 2014, 8:07 am
Thanks Guys Tore
Tore
Tore
Post  bbf-falcon March 9th 2014, 8:16 am
Chewing gum.
Weld seepage Empty Seep
Post  747JetMech March 9th 2014, 7:42 pm
Tore
You can use a aircraft fuel tank sealant. It is a 2 part sealant that dries very slow, about 12 hours. PM me if you want the info on where to order it..
747JetMech
747JetMech
Weld seepage Empty example.........
Post  747JetMech March 9th 2014, 7:47 pm
http://www.skygeek.com/prc-desoto-pr-1440b2-sealant-5-oz.html?utm_source=googlebase&utm_medium=shoppingengine&utm_content=prc-desoto-pr-1440b2-sealant-5-oz&utm_campaign=froogle&gclid=COW_rZjRhr0CFQ5gMgod5lcA3g
747JetMech
747JetMech
Post  Tore March 9th 2014, 8:18 pm
I put JB weld on it today and will see how that works.
If the JB and the gum don't work I will get with you.
Tore
Tore
Tore
Post  maverick March 10th 2014, 5:37 pm
The JB is gonna do the trick. Larry's right...the JB quick stuff is crap...the slow stuff is bulletproof.
Post  richter69 March 10th 2014, 6:22 pm
ive had good luck w the jb quick, just gotta clean the surface real good and use several layers.
Post  supervel45 March 10th 2014, 6:54 pm
https://www.youtube.com/watch?v=sZB7sO5ZoV8 With buble gum over it.
Post  maverick March 10th 2014, 6:57 pm
The JB Quick I used years ago was as brittle as bondo. I gave up on the stuff after 1 try. They musta made a better formula since then Suspect ...maybe I'll give it another shot.
