np205
+6
460pulling
crittersf1
samiam
pajsid44
10 posters
np205 Empty np205
Post  cool40 March 10th 2014, 7:07 pm
How strong is a mid 70s np205? Wondering about a pulling truck application. 35"tires 485"iron head class.
np205 Empty Re: np205
Post  schmitty March 10th 2014, 9:02 pm
Depending upon how much cowbell you are making, they need a few to a lot of parts to live. But that is the strongest factory case made.
np205 Empty 205 aftermarket parts
Post  pajsid44 March 10th 2014, 9:17 pm
http://www.pulloff.com/phorum/read.php?3,171506,171506#msg-171506
pajsid44
pajsid44
Post  samiam March 11th 2014, 1:30 am
I've see a lot of broken parts at the track. only once did I see a 205 hurt, and they are the standard for a good rig
samiam
samiam
Post  crittersf1 March 11th 2014, 8:35 am
I've broken one since 1993.
crittersf1
crittersf1
np205 Empty Strong
Post  460pulling March 11th 2014, 9:54 am
The only ones I've ever seen break were from bad drivers ( bouncing and held it wide open or dumping the clutch from lack of clutch). Two of my friends pull 4x4 and are both over 4-5 seasons old with the original np205s.
460pulling
Post  cool40 March 11th 2014, 10:55 am
pajsid44 wrote:http://www.pulloff.com/phorum/read.php?3,171506,171506#msg-171506
looks like it can be made to live for sure,thanks for the link.
Post  cool40 March 11th 2014, 11:06 am
I have a 74? I think 3/4 ton.dana 60 rear, 44 closed knuckle front.I'm told the front must go or it'll get broke. The class is a prostreet deal.485"oem heads, oem drive line meaning no profab case.35"street tires.how much cow bell is unknown for now but a solid 800hp should put me in the game.I know it'll take rpm to get that much out of a 485 but best I can tell rpm and sled pulling go together. Lol
Post  79Puller March 11th 2014, 6:10 pm
Pro-Fab makes a nice kit for these but limited to 4lo, Cory Keck out of Pa makes a nice kit also with a choice different gears being offered.  Kecks kit can be used in 4lo and limit 2wd for around pits etc. They will never know you have a profab or the other kit inside the case
79Puller
np205 Empty axles
Post  460pulling March 11th 2014, 6:37 pm
I would be more worried about the 44 and the 60 than the transfer case. in my opinion u will be running a dana 70 or 80 in the rear and atleast a 60 up front. Its cheaper to put a bigger differential in than to try and strengthen the weaker 60 in the rear.
460pulling
Post  cool40 March 11th 2014, 8:29 pm
I've been doing some research and found that the 2005 f250 I drive has a 60 front.now I'm leaning toward a superduty to build on.I found a 04 gas burner 6spd for $3600.I just wonder what kinda weight the newer truck is.
Post  79Puller March 12th 2014, 11:24 am
I missed that , jesse has a good point just put a 80 in the rear and 60 in the front.  May want to put 70 outers in the 60. If you go with the newer frame get the 271 case and you will not have to worry about the 205. The 271 is a strong case.
79Puller
Post  cool40 March 12th 2014, 1:52 pm
79Puller wrote:I missed that , jesse has a good point just put a 80 in the rear and 60 in the front.  May want to put 70 outers in the 60. If you go with the newer frame get the 271 case and you will not have to worry about the 205. The 271 is a strong case.
What did the 271 come in?
Post  HorsinAround March 12th 2014, 5:31 pm
Anything you get from Cory will be top shelf! I just wish he had this stuff available when I was still pulling. I tried to make a stock 205 live behind a 700 horse motor and kept popping the rear c clip off and loosing rear wheel drive. Then I went to the profab kit and never had another problem with an 800+ motor.
In stock form, the 1356 is actually stronger than the 205, but the 205 has the better Iron case.
http://www.frontpagefab.com
Post  cool40 March 12th 2014, 7:42 pm
Thanks for all the info everyone. Now i need to decide if I want to jump in this or not. Lol
Post  460pulling March 14th 2014, 12:53 pm
You can have the best stuff imaginable and track conditions suck and still break stuff. It is as a fun "hobby" and if you start you may not wanna stop. Just don't look back at the money spent or you will wonder why it took so much to get to a certain point. I ask a lot of questions on the pulling forums and guys are pretty honest about what works and what doesn't. But it is a pretty secretive sport just like any other motor sport. And somebody always has more money or knowledge.
460pulling
Post  cool40 March 14th 2014, 5:09 pm
460pulling wrote:You can have the best stuff imaginable and track conditions suck and still break stuff. It is as a fun "hobby" and if you start you may not wanna stop. Just don't look back at the money spent or you will wonder why it took so much to get to a certain point. I ask a lot of questions on the pulling forums and guys are pretty honest about what works and what doesn't.  But it is a pretty secretive sport just like any other motor sport. And somebody always has more money or knowledge.
yes I've figured out already to not believe much you hear from the competition. Lol I may just keep my eye open for a roller and skip the building experience. I know i can build one I just don't have the hankering for that stuff like i did in my younger days. Shocked
Post  HorsinAround March 15th 2014, 9:27 pm
Check the weight on the late model super duties, the frames are stiff and they can be heavy but like anything, you can shave alot of weight if you want to. Also, Im not sure what class you are thinking about, but for altered/super stock you had better be in the 850-900hp range and have a motor that will turn up to 9 grand if you want to be competitive. With the 485 pro stock class, you need north of 950 to be competitive and still turn it up to 9000 revs
AP
Post  cool40 March 15th 2014, 9:41 pm
HorsinAround wrote:Check the weight on the late model super duties, the frames are stiff and they can be heavy but like anything, you can shave alot of weight if you want to. Also, Im not sure what class you are thinking about, but for altered/super stock you had better be in the 850-900hp range and have a motor that will turn up to 9 grand if you want to be competitive. With the 485 pro stock class, you need north of 950 to be competitive and still turn it up to 9000 revs
AP
the weight is a concern with the newer sd truck.with the rules as they are it may be hard to get one down enough to make the weight. the prostock class is what i'm looking at but they have another local bunch working on a "hot gas"class.its more "stock"than anything but the rules are VERY open.right now as they are i could put my 605 in a "stock"truck and run it.i hate to build anything for a class that will soon see a big set of rules.lol....thats why i wanted to know about the np205 becouse i have lots of 500"+ parts and a new set of A460's i need to put to use.
Post  cool40 March 17th 2014, 9:43 pm
from what i can find out the 271 can be found in 99-05 f250's.is this the same 271 your talking about?
Post  79Puller March 18th 2014, 6:03 pm
Yes , those are the ones ...they are good strong cases
79Puller
Post  cool40 March 18th 2014, 10:05 pm
79Puller wrote:Yes , those are the ones ...they are good strong cases
thanks 79puller. Very Happy  i think i'll look for a 2005 up so it'll have a 60 front.
Post  cool40 April 3rd 2014, 1:28 am
i got this beauty! it was too good to pass up,lol.............. we'll see how it pulls a sled! np205 20140402_191002
np205 Empty np205
Post  pajsid44 April 3rd 2014, 8:24 am
I like it...don't forget.. paint don't pull!!
pajsid44
pajsid44
Post  Mike R April 3rd 2014, 6:47 pm
Junky is the new shiny
