Rocker arm replacement
cbsuperduty
Rocker arm replacement Empty Rocker arm replacement
Post  HorsinAround August 10th 2009, 10:18 am
I found a bad rocker last night, so I've decided it's probably time to replace all of them since they are over 4 years old and have seen high rpm all their life. So, I'm wondering what is a good brand. Crane Golds? Crower etc? The ones I'm replacing are Scorpions.
Thanks for any input.
Alan
http://www.frontpagefab.com
Rocker arm replacement Empty Re: Rocker arm replacement
Post  bruno August 10th 2009, 10:20 am
what heads ? and what is your entire build , rpm range etc... ??
http://WWW.CKRME.COM
Post  HorsinAround August 10th 2009, 10:52 am
Iron CJ's, 468CI. lift is close to .8 intake. routinely turn mid 7000's to mid 8000's. Titanium intakes. Upright headers
Post  cbsuperduty August 10th 2009, 10:55 am
Alan - Call Lem and see if he has any of the old Lunati Blues left.
cbsuperduty
cbsuperduty
http://yesdeeretruck.com
Post  dfree383 August 10th 2009, 11:00 am
I'm using comp cams pro ss rocker on mine right now and have no complaints.
Post  schmitty August 10th 2009, 8:43 pm
Crower stainless. They are what Lem used on the A head motor of Phillip Oakley. I bought a set for the mud truck and they are some dandy pieces. You can get them in some off the wall ratios too. I got a set in 1.75. They have 1.73 and 1.8 also.
Post  jason August 17th 2009, 10:53 pm
harland sharps for me , have no problems as of yet , and have 4 years on them . every fall i loosen the rockers up for the winter and look them over before spring.
jason
jason
Post  westsideford August 17th 2009, 11:19 pm
I'm using Angus Rockers made in the USA.
[img]Rocker arm replacement PHTO0046[/img]
westsideford
westsideford
