transmission temp gauge
what temp gauge are you guys useing on the transmission?
Larry T- Posts : 1076
Re: transmission temp gauge
this is the one i have
http://www.summitracing.com/parts/ATM-3357/?image=large
put the sending unit in one of the pressure ports.works good.
norm- Posts : 261
I just bought an Autometer 4357, which is a short sweep electrical gauge. It's simpler to install than the mechanical ones. I think that it should be all thats needed for monitoring trans temp. I installed the Autometer 2286 "temperature manifold" in the trans cooler line coming out of the trans on the way to the cooler, all I have to do is thread the sender into it and route a wire to the gauge.
Gary
Gary
GTmustang- BBF CONTRIBUTOR
I have an Autometer electrical guage as well. I drilled and tapped my deep aluminum pan for the sending unit.
David Cole wrote:I have an Autometer electrical guage as well. I drilled and tapped my deep aluminum pan for the sending unit.
i have the deep pan also is their a place that you shouldnt put the sending unit?i was thinking of putting the sender in the rear of the pan.you dont have to use a bung?the 1/8th npt tap is all thats required?
No bung. Just npt. Mine has a brass bushing that's 3/8 npt with a 1/8 npt hole in the center for the sending unit. Mine is at the rear of the pan just below the transbrake solenoid. It's a powerglide
thanks for the help,i will put this in when i change the fluid out after a few tnt runs.
you can put the sending unit in the pressure port on the side of the trans. no drilling, no fuss.
norm- Posts : 261
» autometer trans temp gauge
» Autometer Ultralite Trans temp gauge
» Question regarding SFI bellhousing for auto transmission, and Automatic Transmission Flexplate Shield
» oil pressure gauge
» autometer amp gauge f/s
