Composite distributor gear
I have spoken with Greg at Tri-Tec Motorsports whop manufacture composite distributor gears.
I believe they supply the likes of Comp Cams, Howards etc.. with carbon ultra poly distributor gears for
many applications. However, the BBF is not listed at Comp or anyone else.
Tri-Tec is in the process of a batch of BBF/351C composite distributor gears. I was told 6 weeks or so.
I think this is great news.
68galaxie- Posts : 351
» distributor gear pin
» Composite Distributor Gears BBF with solid roller cams
» Installing a comp cams composite dist. gear
» distributor gear
» Which distributor gear
» distributor gear
