powerglide info
powerglide info
I have been looking at powerglide transmissions. What I have been seeing is several people are running the stock case with bell housing cut off. A guy told me about a adapter to make one fit bbf. That's one of my questions is one way better than the other. Another question I had was about the case issue that I have read about of the forum's. Is the case problem just with the high horsepower stuff like 1500hp plus. Witch i will be no where close to. Just like to see what different people's thoughts was one this.
garys gt- Posts : 87
Re: powerglide info
The benefits on cutting the bell off and bolting an aftermarket one one are easy ones; adapts to almost any block, sfi approved as a scattershield so no other items needed.
The stock case is good for a lot of power if mounted correctly in the chassis and the pressures aren't set to crazy high numbers. Feel free to call and discuss if you like and you can either buy everything from us or we can at least give you a list of stuff you will need.
903-486-7292
903-486-7292
whatbumper- Posts : 3024
Re: powerglide info
What he said.
