Undercover
steven gregoire
Undercover
I recently bought a 235" Undercover 4 link car. Now I'm just trying to get Ford motor plates from Undercover, and see if i can get the Chevy stink off of the car
steven gregoire- Posts : 68
Re: Undercover
Cool deal! They aren't hard to make if you already have the Chevy plate.
Re: Undercover
nice car for sure..
Ace
Ace
powerstrokeace- Posts : 1496
Re: Undercover
that look like a pic from Atco ! I have plates that you could copy if you have any time problems . Im in NJ.
Tha e plates are for a 2000 <21 inch wide car.
steve1071- Posts : 91
Re: Undercover
thanks for the offer. My plates actually came in UPS about 10 minutes after i posted. That Probably was Atco. The guy i bought the car from was a fellow racing her at New England Dragway, and he did hit the money races
Re: Undercover
cool glad it worked out ,good luck with the new car !
Re: Undercover
Sorry FC, i didnt notice your question. I just finished up a 525 cube with A460 heads
Re: Undercover
i put my engine specs in the "proven build" but quickly, its a
4.125 stroke
4.500 bore
13.5-1 comp
stock 340cc A heads.
TFS intake
star vac pump
A460 block
1050 stinnent Dominator
Ultradyne cam
best run so far 7.72@175 no tuning yet. its very "fat n happy"
4.125 stroke
4.500 bore
13.5-1 comp
TFS intake
star vac pump
A460 block
Ultradyne cam
Re: Undercover
That thing is running good. How much does your car weight with you in it? Mine is 4.29 stroke and 4.42 bore. I have the old A460 Motorsports heads. I run a stock block. Mine weights 1944lbs and been 4.94@138 and 7.80@170.
Re: Undercover
those are respectable times. I have my cam 2 degrees back (on ultradyne's recommendation) so my 60' is alittle soft (1.155) but it runs good at the 1/8 4.80@140, and i also attribute that to my higher 1/4 MPH
i put my tight ATI 8" converter in it from my door car. It is only slipping 4% at the stripe. so its a pretty efficient set up
i was so busy getting it all together that i didnt get a chance to put it across the track scale yet. i will do that this weekend, and let you know
Re: Undercover
Yea my cam is retarded 2* also but that was to get the intake valve to clear the piston. My best 60ft has been 1.13 but consistently at 1.15.
» C-HEADED MANIFOLD DISTRIBUTOR ?
» '96 UnderCover Dragster for Sale
» 2000 undercover 4 link dragster
» Fabricated 9" housing from Undercover hardtail dragster.
