lost a rod bearing
+7
Wheelie58
strokedmyford
11 posters
lost a rod bearing
Lost a rod bearing on the dyno yesterday trying to figure out why.
Build details
A460 block bore 4.530 (used bought from a forum member)
stroke ohio crank 4.6
crane cam .740 lift 280's dur.
trickflow A460 360cc heads New
single 1450 quick fuel (used bought from a forum member)
callies 6.7 BBC compstar I beam rods
King 3/4 groove mains
king rod bearings
diamond +12cc domes
Kaase oil pump
moroso drag race oil pan
10 qrts val. 20w50
When I had the assembly balanced I asked the machinist to check the clearances and he said use std.X brgs. on the rods and std. on the mains. I plastic gauged a couple rods and a couple mains clearances looked to be .003 on the mains and .0025 on the rods (I know plastic gauge isn't perfect but its all I have). I have been putting the parts together over the years for a personal project but lost interest and a fellow mud racer asked me for advice on a simple low maintenance 900 horse build. I saw an opportunity to get out from under the parts I collected and help a fellow racer out so he gave me a deposit to finish the build. Assuming the all the clearances were correct and assembled correctly. I posted some pictures of the ohio crank and a higher end callies crank has anybody had any trouble with the oil holes to the rods not being centered in the rod bearing being an issue.
It did look like it was wanting to run first pull was 831 torque @ 4700 894 hp @ 6800 then went south.
Build details
king rod bearings
diamond +12cc domes
Kaase oil pump
10 qrts val. 20w50
strokedmyford- Posts : 126
Re: lost a rod bearing
Clearance is critical on bigger engines, did you measure for taper and out of round? What rods? Did you measure the Rods? Do you have enough piston to head clearance?
Did you prime it?
Did you prime it?
I left the measuring up to my machinist I am more of an engine assembly man.
Rod are listed it the build details
When assembling domes were hitting the heads but after a little massaging I got the engine to turn over nice without a head gasket and used a cometic .045
After disassembly the only piston showing contact was the one with the bad rod bearing but with the rod bearing lying in the pan all evidence is gone if it was contacting before.
when I did prime it I thought way to much oil was going up top so i double check the restrictor plug it had a 5/64 hole in it and the rear inner plug was installed. I still could not believe that much oil could come through that small hole.
Another note the oil psi stayed at 64-62 lbs. untill 6400 rpm then dropped a little ending up 56lbs. at 6800 rpm
piston hit the head i had the same deal last year.
I plan on adding some extra clearance when I go back together, just trying to rule out any other issues.cool40 wrote:piston hit the head i had the same deal last year.
how much oil did you have in this engine, sounds like it ran low filling up the valve cover area.
when you were priming it what did it look like in under the valve cover?
also how long did you prime it for?
BOSS 429- Posts : 2372
Getting correct oil clearance is not the only thing to be checked upon pre-assembly.
1. are all the rod big end bores STRAIGHT and ROUND?
2. do the crankshaft journals exhibit perfectly ROUND and very little tapper journals of the CORRECT SIZE with good surface finish? (You can't see minor chatter with the naked eye)
3. Are the main bores in the block STRAIGHT and ROUND"
4. are the bores perpendicular to the crankshaft centerline?
Is there evidence of "radius ride"?
If the journals fillet was touching the bearing, it will definitely cause early failure.
Easy to overlook.
Keith
Easy to overlook.
Keith
Dennis,
Well of the two different cranks you have pictured, I'd much rather be using the one with the gray colored cheeks and counterweights, than the one with the black colored cheeks and counterweights. The gray colored one has a much bigger and nicer fillet radius than the black colored one, and I believe will prove to be the stronger crank.
I do think you have an oiling problem, that is related to the clocking and location of those oil holes in the black crank.
Another thing I noticed on the black crank is, that on it's main journals, I see that they chamfered BOTH the leading and trailing edge of the main oil hole. IMO that's wrong on the mains and allows the main to bleed off oil pressure. Only the leading edge of the main oil hole should be chamfered, as this helps capture and maintain oil pressure going to the rod bearings. I could not see the main bearing oiling hole on the gray crank, however if we could see and study it, I suspect it only has the leading edge chamfered.
Did the rod bearing that went south occur on cylinder numbers 3, 4, or 7?
Charlie
Charlie
c.evans- BBF VENDOR SPONSOR
No expert, but I do not like the black crank. It looks like it would only oil one side of the rod bearings, the way the holes are spaced. You did not mention how much side clearance you where running on the rods, but if it is on the loose side, it would seem like you would loose alot of pressure between the center of them, and not oil evenly across the bearing?
supervel45- Posts : 4499
BOSS 429 wrote:how much oil did you have in this engine, sounds like it ran low filling up the valve cover area.
10 qrts
plenty of oil up top it was a concern mentioned in earlier post
primed until all rocker arms had oil, I turn the engine over while priming
rmcomprandy wrote:Getting correct oil clearance is not the only thing to be checked upon pre-assembly.
I know the block is spot on engine systems done the machining
The rest of the parts were new but I relied on my local machinist to check over.
Wheelie58 wrote:Is there evidence of "radius ride"?
Easy to overlook.
Keith
I was careful on disassembly to make sure the upper and lower rod bearing were correct but the one that spun all evidence was lost.
I did install the bearings incorrectly to check if that could have been an issue, even incorrectly the radius didn't touch the bearing.
The gray colored crank is the callies the bad thing is I'm stuck with the Ohio 4.6 stroke to keep in budget They had a new crank I stressed to them I need this to be right. I know of a few guys running this crank making north of 1000hp with success.c.evans wrote:Dennis,
Charlie
It was #2 that spun
the callies crank only has the leading edge chamfered
I'm beginning to think maybe I didn't clearance the dome enough and after warm up it came in contact with the head
supervel45 wrote:No expert, but I do not like the black crank. It looks like it would only oil one side of the rod bearings, the way the holes are spaced. You did not mention how much side clearance you where running on the rods, but if it is on the loose side, it would seem like you would loose alot of pressure between the center of them, and not oil evenly across the bearing?
I never measured the side clearance I just know that the rods moved freely side to side.
On the new crank I had them add a some chamfer to the oil hole toward the radius side.
If a piston hits a head it will kill the bearing.
I know for a fact that the OHIO cranks are fat and out of round and need to be machined before any thing else. these are not plug and play. I happen to have one that my crank grinder said finish the rods and the align hone first. Install the bearing and give him the measurements. from that he finished the crank and its spot on. As for the piston hitting the heads i have a whole nother comment i'll keep to myself. But since you lost the bearing it had extra play so it would hit the head. So the delema is what was the real failure? did the piston hit befor the rod failed or after
Ace
Ace
Last edited by powerstrokeace on April 10th 2014, 12:07 am; edited 1 time in total
powerstrokeace- Posts : 1496
Were the 360 cnc heads the 85cc chambers? If so, they take a bastard dome. I do not use them.
Lem Evans wrote:Were the 360 cnc heads the 85cc chambers? If so, they take a bastard dome. I do not use them.
they are the 85cc
powerstrokeace wrote:I know for a fact that the OHIO cranks are fat and out of round and need to be machined before any thing else. these are not plug and play. I happen to have one that my crank grinder said finish the rods and the align hone first. Install the bearing and give him the measurements. from that he finished the crank and its spot on. As for the piston hitting the heads i have a whole nother comment i'll keep to myself. But since you lost the bearing it had extra play so it would hit the head. So the delema is what was the real failure? did the piston hit befor the rod failed or after Ace
I did pay to have the crank that failed checked out and tuned up if necessary but I can't verify if he did his job, being a tight ass and saving some money on freight and using a local guy probably bit me in the ass
I'm not one to make accuses I just like to find the problem and move on, being my error or someone else's.
They actually called me and said ''to be quit honest they should not be going out the door this out of shape'' The new one they tuned it up on the grinder and clearances should be good with a std. bearing.
powerstrokeace wrote:I know for a fact that the OHIO cranks are fat and out of round and need to be machined before any thing else. these are not plug and play. I happen to have one that my crank grinder said finish the rods and the align hone first. Install the bearing and give him the measurements. from that he finished the crank and its spot on. As for the piston hitting the heads i have a whole nother comment i'll keep to myself. But since you lost the bearing it had extra play so it would hit the head. So the delema is what was the real failure? did the piston hit befor the rod failed or after It should not be too hard to install a new bearing on the suspect rod/piston, and mock the engine back up and check clearance on the head. Did your Ohio crank have the oil holes drilled like this one does? Randy also mentioned checking the rod big end for roundness, and that needs to be done now since the bearing spun on it anyway. Hope you get to the bottom of it.
Ace
The above quote went wrong. The top part is from Powerstrokeace, and the bottom was mine. Don't know what went wrong, sorry, abot that.
» KING MAIN BEARING CLEARANCE'S AT PARTING LINE..?
» HELP!!! LOST DOG
» Lost that bet, lol
» lost my job today
» Once lost but now found
» HELP!!! LOST DOG
» lost my job today
