SOLD
+9
bigjohn2007
Mustang-junky
70FB
4thHorseman
8liter
Dave C.
shelby_67
13 posters
Page 1 of 2
Page 1 of 2 • 1, 2
shelby_67- Posts : 125
Re: SOLD
Methanol? Dry sump? Looks sweet.
8liter- Posts : 202
Re: SOLD
Looks like it'll haul the mail!
4thHorseman- Posts : 400
Re: SOLD
Any updates on this?
70FB- BBF CONTRIBUTOR
Re: SOLD
Not sure i this helps, but he has a little more info on the other site about his build.
http://www.460ford.com/forum/showthread.php?t=184457
Jess
Jess
Mustang-junky- Posts : 438
Re: SOLD
One word "AMAZING"
bigjohn2007- BBF CONTRIBUTOR
Re: SOLD
Nice. Is that the TFS intake machined for injectors?
jasonf- BBF CONTRIBUTOR
Re: SOLD
Why didn't you wye the lines going into and out of the rails instead of the way they are plumbed now? Did the cam get ground specifically for your application since the compression is so high so it will bleed some of the cylinder pressure? Who's building the start tune?
whatbumper- Posts : 3024
Re: SOLD
evens out the fuel pressure so it feeds both rails evenly. if I were you I would redo it.
is this going to be bank to bank injected or sequential? I'm not sure what the BS3 can do but I would think sequential if you run a crank and cam trigger. not that it's needed in this case.
bbfhnj- Posts : 13
Re: SOLD
I just realized you probably have a T at the back corner (can't see it) like you do at the front corner?
if so it's that's not as bad as if you had just fed one rail and crossed over then fed the other rail then went to the FPR.
with the being said those T fittings are just not as good as a Y because the fuel has to make a 90* turn twice! 90* are a greater restriction which in turn is more work for the pump, and the more fuel your combo needs the worse the problem gets.
but do what you want.
bbfhnj- Posts : 13
Re: SOLD
shelby_67 wrote:Sequential
The fuel is -10 in and -8 out to aeromotive 13110 and -10 back to tank has belt drive red aeromotive pump was system is pressurized why would the fuel not be feed evenly ? One rail will not use more than the other ?
You can plumb it however you want. We just have done a lot of them and have tons of data to prove why we do it the way we do. You are correct that the entire system is pressurized but you also need to remember the firing of the injectors and refilling the rails in a sequential system. You may, not guaranteed, have to work on injector pulse width individually which is not hard to do but takes some time to gather that data.
Your tuning window is going to be tiny with that much compression with that much air moving through the system unless your cam is spec'd accordingly which is why I asked that earlier.
Any setup will work when set up correctly for the parts in hand so I'm not saying it will not work but that you need to trust your tuner and don't mix and match information from different people trying to take the best.
Re: SOLD
Any update on this????
Re: SOLD
Sweet. Doesnt look like you are to far away from cranking her up..
Re: SOLD
Love to hear what numbers it posts on the rear wheel dyno & drag strip.
Dark Horse of Apocalypse- Posts : 171
Re: SOLD
Ready to hear some numbers in here.!!!
Page 1 of 2 • 1, 2
» Weld gold Mag. front 15" rims brand new SOLD SOLD SOLD SOLD
» FOR SALE - COMP CAMS CHROME MOLY ROLLER ROCKERS SOLD SOLD SOLD
» for sale one ONLY 429CJ/SCJ factory aluminum valve cover SOLD, SOLD, SOLD
» moroso electric water pump price reduced sold sold sold
» Quick Fuel Carb 4150 base 1050 cfm SOLD SOLD SOLD
Page 1 of 2
