np 271
np 271 Empty np 271
Post  cool40 April 24th 2014, 9:19 am
I have a 2008 f350 srw im planning to build for pulling. Will the np271 in this truck mount to the old np435 trans? Is it possible to run it divorced?
np 271 Empty options
Post  460pulling April 28th 2014, 7:57 am
I know you can get a NP271 out of some of the automatic trans versions with 31 spline input or you could swap a 31 spline input into the case you have and then it would marry to your NP435. As far as making it a divorced setup I am not sure as I have not ever seen it.
I was talking to Cory Keck yesterday at his shop and He said there was a BW 4407 that came in 95-97 ford 1 tons. He said they a strong case. He makes alot of NP 205 stuff. I would give him a call. I think he could definitely help you out. He knows a lot about the Np205 limits and what needed strengthened. I added his contact info below.
Cory Keck
President
Keck's Machine and Performance Design
259 Mill Rd Clarks Mills, PA 16114
Kecksmachine@gmail.com
(724)-699-8820
Text anytime or please call after 5 EST or weekends.
460pulling
np 271 Empty Re: np 271
Post  cool40 April 28th 2014, 12:08 pm
Thanks for the info! I bought a 2008 350 srw to build with.its a 5.4 auto so ill check it out and see what spline it is.if the shaft would work i can machine up an adapter plate.  Cool
Post  79Puller May 6th 2014, 10:38 pm
Did you get that 271 put in yet.
79Puller
Post  cool40 May 7th 2014, 12:57 am
79Puller wrote:Did you get that 271 put in yet.
no I've ran into a problem.the low ratio wont work out for my 4.10 gears with the old 4spd.im leaning toward keeping the 205 for now.I got the f350 took apart today and looks like a healthy running gear.I first planned to swap axles to the old frame but now i'm thinking ill cut this one down to 137" and swap an old body over to it.that 08 front d60 sure has a set of trailing arms on it!
