Crankshaft diamiter at crank gear
+6
kjett
powerstrokeace
10 posters
Crankshaft diamiter at crank gear  Empty Crankshaft diamiter at crank gear
Post  powerstrokeace April 27th 2014, 11:16 pm
So I'm wonder what the demension is of the crankshaft where the crank gear is. I'm trying to degree the cam but can even get the damn gear on. I'm coming up with 1.384-1.385. And the gear is 1.381ish?
Ace
powerstrokeace
powerstrokeace
Crankshaft diamiter at crank gear  Empty Re: Crankshaft diamiter at crank gear
Post  bbf-falcon April 28th 2014, 4:56 am
Hone
Post  powerstrokeace April 28th 2014, 7:56 am
bbf-falcon wrote:Hone
Nope this crankshaft was fat all the way around. I have 3 gears and they all fit a stock crank I have here in the garage. I may be pulling this thing out tonight and back to the grinders
Ace
powerstrokeace
powerstrokeace
Post  dfree383 April 28th 2014, 8:43 am
Gone the crank gear and balancer?
Post  powerstrokeace April 28th 2014, 9:25 am
dfree383 wrote:Gone the crank gear and balancer?
How are they going to hone a 9 position gear? Would it no catch ?
Ace
powerstrokeace
powerstrokeace
Post  cool40 April 28th 2014, 9:37 am
Who's crank?
Post  powerstrokeace April 28th 2014, 10:17 am
cool40 wrote:Who's crank?
Don't ask... :-(
Ace
powerstrokeace
powerstrokeace
Post  kjett April 28th 2014, 11:24 am
If the snout is larger than it's suppoed to be, why not just hone the snout to the proper size?
kjett
kjett
Post  maverick April 28th 2014, 11:42 am
kjett wrote:If the snout is larger than it's suppoed to be, why not just hone the snout to the proper size?
I think machining the snout is what he means when he says, "back to the grinders".
Post  kjett April 28th 2014, 11:45 am
Guessing so.  Rolling Eyes
kjett
kjett
Post  69bluehotrod April 28th 2014, 11:57 am
Ohio crankshaft????
69bluehotrod
69bluehotrod
http://rainbowvacuumsalesservice.com/
Post  cool40 April 28th 2014, 11:58 am
Don't ask... :-(
Ace
 silent
Post  powerstrokeace April 28th 2014, 12:06 pm
69bluehotrod wrote:Ohio crankshaft????
Yep. I got it in a trade deal and don't have anything in it for the most part. I will never recommend one to any one....
So is it possible to have a multiple position crank gear honed out?
Ace
powerstrokeace
powerstrokeace
Post  Frank Merkl April 28th 2014, 1:56 pm
I like a little press fit for the gear !heat the gear up with a heat gun and side it on ! all the Danny Bee the crank sprockets have a press fit
Post  Paul Kane April 30th 2014, 11:32 am
powerstrokeace wrote:...this crankshaft was fat all the way around. I have 3 gears and they all fit a stock crank I have here in the garage. I may be pulling this thing out tonight and back to the grinders.
This can be adjusted with a bit of of polishing. You don't even need a big crankshaft grinding house to do it, it can even be done on a lathe with some emery cloth.
This is no different from, say, fitting a new piston ring into a bore, determining the end gap is too tight, and deciding it needs to be filed.
Post  powerstrokeace April 30th 2014, 11:43 am
We were able to polish out the gear in order to make it fit and everything is good thanks guys
Ace
powerstrokeace
powerstrokeace
Post  460Dave April 30th 2014, 4:31 pm
I had the exact same issue with a new Lunati crank a couple of months ago.
460Dave
Post  maverick April 30th 2014, 4:39 pm
powerstrokeace wrote:We were able to polish out the gear in order to make it fit and everything is good thanks guys
Ace
460Dave wrote:I had the exact same issue with a new Lunati crank a couple of months ago.
What?? No apologies to Ohio Crank?? Laughing
