1995 F350 Over Drive "OFF" Blinking
D. Sea
Went racing this past weekend (For another topic) but towing home I had it cruising at 65mph when the cruise control stopped and the "OFF" light on the overdrive arm starts blinking. Did this for a few minutes and then stopped.
Cruise control works again
Sensor somewhere going bad?
D. Sea- Posts : 2768
Re: 1995 F350 Over Drive "OFF" Blinking
Maybe the clock spring in the column?
jbozzelle- Posts : 3705
jbozzelle wrote:Maybe the clock spring in the column?
clock spring? Not sure if serious
Googled it a few minutes ago. Going to check the VSS sensor over the rear differential as most of the time this is the issue according to what I researched. Second would be speedo cluster or something? Hear something rattling around in there as well.
Get a code out of the pcm, cruise shut off due to the trans issue.
There are only a few things that cause the cruise control to not work or to work intermittently
Burned out taillight or brake light.
Brake light switch
Bad speed sensor signal to the PCM.
Pressure switch on the master cylinder on it's way out. This is the little sensor/switch on the end of the brake master cylinder.
The range position sensor faulty. This is the sensor on the side of the transmission. Even though it may ohm out fine, it will not give a consistently good signal to the PCM.
The wires at the end of the shifter could be broken
Cruise control itself could be bad
Trailer wiring or trailer lights
Multi function switch going bad.
Need a code ! Hope this helps !
Brake light switch
whitefield- Posts : 2244
+Emer. brake pedel not completely released.whitefield wrote: There are only a few things that cause the cruise control to not work or to work intermittently
Brake light switch
D. Sea wrote:Went racing this past weekend (For another topic) but towing home I had it cruising at 65mph when the cruise control stopped and the "OFF" light on the overdrive arm starts blinking. Did this for a few minutes and then stopped.
I have a 95 carhauler that the od light is blinking also and the overdrive stopped working completely,haven't had the time to code it yet.
Thanks guys
Unfortunately I didn't get a chance to work on the truck last night. Was working on Dads tractor and Brothers Camaro. My brother doesn't know it yet but I'm getting his car ready to race so he doesn't have to race his Honda Civic
However his payment will be a 429-460.com decal on the back glass
D. Sea wrote:Thanks guys
If that's all the payment is, come on over and work on my turd.
HorsinAround wrote:D. Sea wrote:Thanks guys
Deal!
I'll need to borrow your torch, sledge hammer and duct tape
Swapped out the ABS/VSS sensor over the rear differential but no good. Still shuts down Intermittently. Guess I need to get it coded and find out what's up. Also noticed that the cruise control, when engaged, is surging as the speedometer moves up and down a few mph.
Update:
Finally got it on a code machine and it didn't have any codes. So after speaking with my old racing buddy who scanned the truck (He also owns a transmission shop) and then confirming it with Mike; we believe the shift solenoid pack may be acting up. So when I get a chance, I'll drop the pan and see what's up. Mike is checking on the parts I need. Thanks Mike!
To Be Continued.
To Be Continued.
Damon,is it still acting up or did it do it just the once? I was coming back from Bristol through the mountains and mine started blinking.After i got back to normal towing and the tranny cooled it didn't act up anymore,but i had to put 3qts of fluid in it when i got home.
Rick,
It's hit and miss and unpredictable. May go all day with no issues or go to kroger, get gas and then it acts up on the way home. Very odd that it didn't throw any codes. Trans fluid level is in normal range.
After I get my bobcat fixed then I'll look into the truck.
I've also got a 95 psd car hauler that slips while in OD and the light was blinking before it started slipping .At least thats what the previous owner told me.
This transmission was totally rebuilt within the last 5K miles. I've put about 2K on the truck within the last 3 years. Mostly just towing the race car or picking up supplies for ?????
D. Sea wrote:Rick,
I hope you put him to sleep before you fix him, otherwise that will be one pissed off pussycat!
AZFairlane- BBF CONTRIBUTOR
AZFairlane wrote:D. Sea wrote:Rick,
Unfortunately the Bobcat didn't get fixed this weekend. Ran into some seal installation issues and had to order new rod seals which will be here tomorrow.
Maybe tomorrow
» 1995 Ford F350 XLT Crew Cab DRW
» Stroker EFI Build for 1995 F350 Towing Application
» 1995 SUPER CAB RANGER 2W DRIVE
» Front accessories drive with belt drive fuel pump
» belt drive or gear drive
