Stiff Sidewall Slicks
+8
70FB
67460
yellowhorse7
Dave C.
12 posters
Getting ready to buy slicks and was wanting to know if anyone is running them and what you think about them?
Dave C.- Posts : 1268
Re: Stiff Sidewall Slicks
I run M/T ss and can't complain about the performance. They dont hold air for shit so tubes would be a plus.if your gona be pretty hard on the tire a ss with tubes is a good idea.
What size tire? I've run the Hoosier 32X14.5W stiff sidewall. Measures 32X15 with `102 rollout. It worked well in my car at close to 3000 lbs. Keith Fulp runs it on his '58 I think. I've since swapped to the regular sidewall Hoosier 15X33 because I wanted the extra rollout to ~104. Saw no diff in performance.
I have to run a stiffwall on mine
yellowhorse7- Posts : 1382
Caveman tank tracks
31x14's 650 hp.. 3000 lbs
IMO it will make less difference with a tire that wide but they will not hurt if the car hits the tires hard or makes the power to hit the tires harder.
A ss will help top end stability especially without tubes.
I had a pair of soft sidewall Goodyears (32 X 16) on my car...it launched like a pogo stick until I swapped on a set of Hoosier stiif sidewalls (31.5 X14.5 W). I'm a fan of Hoosiers for big tire cars.
maverick- BBF CONTRIBUTOR
cool40 wrote:A ss will help top end stability especially without tubes.
X2. But it won't be as obvious in a 10 sec car vs a 7 sec car. But I don't know how fast his car is......
cool40 wrote:I run M/T ss and can't complain about the performance. They dont hold air for shit so tubes would be a plus.if your gona be pretty hard on the tire a ss with tubes is a good idea.
x2
I run the same tire and just put tubes in them got tire of air comming out all the time.
67460- Posts : 384
29.5x10.5,ss but have only been 6.12s 9.62. No tubes and they need air every week racing or not. I will go back to tubes next time.
70FB- BBF CONTRIBUTOR
The Hoosiers on my car (31.5x13.5W) hold air better than any slicks I've ever had. I put the car in the garage a month ago for a trans rebuild. They had 7 lbs. in them then. Today they had a hair over 6 lbs. No tubes.
I've thought about trying a set but have heard a few folks say they had no luck with them. I never had any reason to change from m/t except for that air problem when ran tubeless.I'm still considering a set though. Lolmaverick wrote:The Hoosiers on my car (31.5x13.5W) hold air better than any slicks I've ever had. I put the car in the garage a month ago for a trans rebuild. They had 7 lbs. in them then. Today they had a hair over 6 lbs. No tubes.
I got 31x10.5w M/T no tubes they hold air great never have had a problem with them leaking but they are a set I bought from Jon he might have put the HERO touch on them
hoosier wont leak tubeless and dont need soap. Daves deal will be a high 5 low 6 sec 1/8 mile deal
i did the soap deal with the last set and they still wont hold air.if i dont try hoosier i'm going with tubes again.richter69 wrote:hoosier wont leak tubeless and dont need soap. Daves deal will be a high 5 low 6 sec 1/8 mile deal
From what I have seen Hoosier's do seem to hold air the longest over time. And Goodyears are probably the worst at holding air over time.
DILLIGASDAVE- Posts : 2262
Mine (Hoosier #18260) leaked like Grandma's collander when I first mounted them. Musta been bead leaks because after I ran 'em the first time, they just quit leaking. No soaping or any special treatment. They also work much better on the track. 5.70's car. I'm sold.
x2maverick wrote:I had a pair of soft sidewall Goodyears (32 X 16) on my car...it launched like a pogo stick until I swapped on a set of Hoosier stiif sidewalls (31.5 X14.5 W). I'm a fan of Hoosiers for big tire cars.
bigjohn2007- BBF CONTRIBUTOR
Goodyear D1408. pretty stiff - put 2 coats of Slime in them before mounting - usually works pretty good. The biggest issue I have is they start going away about 50 passes... still plenty of rubber but 60's fall off and get more and more inconsistant. I used to run thr GY 2052 - they were crap at 30 passes. Hitting the tire pretty hard at 3000 lbswith a 1.25 or so 60'. Been thinking of trying the MT's next - what do you guys get for runs out of them?
Kurt
Kurt
504T- Posts : 64
» M/T 28X10.5 STIFF
» M/T 28 x 10.5 x 15 stiff wall, ET Drags, New
» 28" x 10.5" x 15" M/T ET Drags and tubes, stiff wall
» Slicks
» M/T ET Slicks
» Slicks
» M/T ET Slicks
