C 6 locking up?
C 6 locking up? Empty C 6 locking up?
Post  67460 May 9th 2014, 12:39 pm
Trans runs great doing 1/4 mile pass. After I go thru the traps when I slow down to go get slip I leave it in 3rd. Once I get the
slip I shift down to 1st then try and leave trans locks up. I have to stop put in park then back into 1st in order to move the car.
I am thinking the convertor is lock up in the trans. Anyone have this problem before?
67460
67460
C 6 locking up? Empty Re: C 6 locking up?
Post  aquartlow May 9th 2014, 6:42 pm
Could the shift linkage be a touch off? Years ago I once had an issue with my Ranchero where it would get hot and vapor lock, while driving down the road. I would shift it (column shift with cable linkage to trans) into "N" and attempt to start it while still moving. When I engaged the starter in trying to start it, it would lock up the transmission(left tire marks while going 40 or so). I finally figured out that the linkage was just off enough for the trans to act like it was in neutral until I attempted to start it, doing so made the trans go into reverse, even though it would coast when not trying to start it. Hope this makes sense. Todd
aquartlow
aquartlow
Post  67460 May 10th 2014, 10:29 am
Makes a lo sense
I have had problems with the shift linkage before. I will go over it again.
Thank you.
67460
67460
